Question about HP Printer Cartridges (Complete List): , HP 4836A (replaces HP 11) cyan ink cartridges
Problem with refilled HP 27 cartridge
I have refilled a HP 27 cartridge. Unfortunately it was excess filled and the ink ozzed/ overflowed fromthe front nozzles. It is now showing cartridge error and asking to replace the cartidge. Can the cartridge be made in running condition.
  • pankaj_cciit Feb 28, 2009
    I have fully emptied the cartridge, still it does not work. contact points are all clean.
    Please, somebody can help?
    Sergeant:
  • 199 Answers
Remove some ink from the cartridge and clean the contact point of the cartridge and inside the printer, then hold the cartridge. when the cartridge not drop ink fix the in the printer
Posted on Feb 27, 2009
I have refilled my color and black cartridges and now I am getting "hp inkjet f2400 invalid cartridge".
Hi:
This is why manufactures suggest you do not use refill ink kits. Because the ink is not always compatiable with the printers, they are some times to thick and will overflow and cause errors. There are ink sensors on the cartridges to determine the kind of ink in the cartridge. Try using only the manufature ink cartridges to as much as possible.
May 31, 2011 | HP Printer Cartridges (Complete List): ,...
Red not printing
if replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
Dec 02, 2010 | HP Photosmart C7280 Printer
How I can refill my HP 27 Cartridge at home...
please follow the instructions........
  • 1
    Purchase an ink refill kit that is specific for the HP 27 color ink cartridge. Look over the packaging to insure that it states that the kit is for the particular make and model. Using other types of cartridges may not work properly.
  • 2
    Place several paper towels down to prevent any ink residue from damaging other objects. Place the ink cartridge onto the paper towels. Put on a pair of rubber gloves to prevent ink from staining hands.
  • 3
    Peel off the top label gently from the cartridge.
  • 4
    Observe the three holes that are located on top of the cartridge. There is a solo hole located near a rectangular tab that protrudes and two other holes located next two rectangular indentations into the plastic on the top of the cartridge.
  • 5
    Take a toothpick and gently stick it down inside each hole to verify the color. Take a sharpie marker and mark next to each hole with the correct coloring for ease. Use "M" for the magenta color, "Y" for yellow and "B" for blue.
  • 6
    Take a piece of masking tape and place over two of the holes to prevent ink spillage from mixing into other color positions.
  • 7
    Read over the ink cartridge refill kit for the appropriate amount of ink needed to fill the syringe with the correct color for the uncovered hole.
  • 8
    Expel any excessive ink from the syringe. Insure that you have the correct amount of ink by following the markers on the side of the syringe.
  • 9
    Place a paper towel over the end of the syringe and while holding the tip upwards, gently press or tap the syringe plunger to expel any air.
  • 10
    Insert the syringe needle into the appropriate color hole until the tip hits the bottom of the cartridge. Pull the syringe up a little from the bottom of the cartridge to prevent blockage when expelling ink.
  • 11
    Expel the ink into the color hole slowly. Stop if ink begins to protrude out of the color hole. Take a cotton swab and gently wipe the outside of the color hole and then cover with tape.
  • 12
    Take the syringe apart and rinse thoroughly to prevent ink colors from blending. Take a cotton swab and dry out the inside of the syringe.
  • 13
    Repeat above steps for the remaining two color positions that are left.
  • 14
    Gently take a needle and put a hole in each tape that covers the color holes for ventilation. Allow the cartridge to sit for at least one hour after completing refill instructions.
  • 15
    Reattach the original top label.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 22, 2010 | Computers & Internet
    How can I make your 8500 pro accept a refilled HP cartrige.
    The HP 940 cartridge is the new version of the HP 88 cartridge. Both have a chip that estimates ink levels. Once the chip says the cartridge is empty it will refuse to print, no matter how much ink is really left in the cartridge. This is a safety measure so you don't get air in your ink lines. If you get air in an ink line, that color will no longer print. We can refill the HP 88 because there are replacement chips available for these cartridges. I own a Cartridge World ink refilling store and I don't refill the HP 940s yet because I don't have access to a replacement chip. If you purchased a refilled HP 940 and it's not working, I would say the chip has not been replaced. I would wait until a reputable refiller (i.e.-Cartridge World, Office Depot, etc..) offers refills for this cartridge before you try anything off the internet.
    Feb 16, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    In the middle of a print job, my cartridge refill stops feeding ink. Printer MN J4680. Does this printer hold the cartridge # in memory in order to stop one from refilling?
    HP printers do not remember the cartridge serial number to reject refills (certain Canon printers do though). It sounds like you have an air bubble in the sponge that is inhibiting ink from reaching the print head. I would guess that either you or the store/internet seller that refilled this cartridge hand filled it. These cartridges should be filled under a vacuum to remove air bubbles from the sponge and allow you to fully fill the cartridge (an air bubble takes up space that your ink could be occupying). I recommend Cartridge World or Office Depot for refills. Avoid internet sellers and refill shops that have one giant all-in-one machine that does the filling for them.
    Oct 09, 2009 | HP J4680 Office Jet All-In-One Printer
    . HP 6210 all in one Kept printing till unplug
    HP will tell you to never refill cartridges because they will not guarantee your printer will print properly with those refilled cartridges. If those refilled cartridges leak and cause damage to your printer HP will also not cover any repairs to the printer regardless of what sort of warranty coverage you have with them. Warranties only cover HP failures, not ones caused by using third-party or refilled ink cartridges. So, no it is not worth having the cartridges refilled - buy new HP-branded ones only.
    Jul 25, 2009 | HP Office Equipment & Supplies
    How to refil ink in hp 2120 cartidge
    actually your printer cartridge was cloted or maybe airlocked.
    You must use tissue paper and rub it on the nozzle side. Ink may flow out.
    sukumar.t.k.
    Jul 30, 2008 | HP Office Equipment & Supplies
    HP 57 refill problem
    You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
    If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
    Feb 12, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
    Refilling ink cartridges
    hp74a.jpg HP #74 Cartridge Refill Instructions
    Black cartridge
    Instructions
    1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
    3. Fill the syringe with 20ml. of black ink.
    4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
    5. When finished, replace the top label or leave it off (it will make no difference in the printing).
    6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
    Or print the following pages:
    http://www.refillinstructions.com/black.htm for Black
    For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
    A Refill Kit should include Ink plus the following:
    One 30cc Syringe
    Jan 14, 2008 | Office Equipment & Supplies
    144 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
