Not found webcam device. check you pc camera.
I already try to press the fn+f10 but still my camera doesn't work.
  • 23 Answers
Actually there's a very legimite soution for this Problem.
Those posted solution of remove battery and others are all blabbering.
First of all, you have to go to start - right click on Computer - properties - device manager
Click on Imaging device (if you can't see the imaging device, you have to press fn + F10)
Then you will see a yellow mark on the device, right click on it - uninstall and put check for delete all files for this device. then up hit " scan for hardware changes " - it will re-install the build in smartcam automatically.
When done it's highly recommended that you restart the pc so that the new changes take effects.
It will be working 100% with no doubts.
Send you comments to rabih_2@hotmail.com
Posted on Aug 07, 2009
How can i get back my camera device in my neo vivid vc2ew, ive already tried to reinstall alll the driver but still doesnt work,,please help me..thanks!
Open the Device Manager, is the webcam listed under Imaging Devices? Enabled? Have you tried a System Restore to a date before this issue? What Webcam Software does your Laptop have? CyberLink? Try unplugging , remove battery, plug in, reboot.
Mar 19, 2013 | Computers & Internet
My lenovo s100 cant view my webcam..or it not dtected
@joefry_dioce
If you're using Yahoo Messenger or Skype to access your webcam and it says No Camera Detected, the camera might be turned-off. Try the following:
1. Presss Fn+ESC (The Fn key is located at the left side of the space bar). that's the hotkey to turn your Webcam ON and OFF and try to check if your Webcam works.
2. Open Device Manager - press the Windows Key+R and type devmgmt.msc on the keyboard (the windows key looks like this ray_tosh_1.jpg ) and look for Imaging Devices
3. If you see your webcam there, try to right click on it and Uninstall and restart your computer and check if your webcam works now.
If that still doesn't work and the webcam light is not turning ON, that's already a sign that your webcam is failing and needs to be replaced. If you're still under warranty, you can Call Lenovo Support at 1-877-453-6686 to have it serviced.
Good luck.
Sep 12, 2011 | Computers & Internet
I have a new zoostorm vme50 and cant get the webcam to work. I've looked on device settings and it isnt listed, i tried Fn & Esc but nothing happened
you need to scan for new hardware and see if recognizes it if not try this
Check if driver for webcam is properly installed. You can check that by going to control panel then click on system then click device manager. The webcam should be listed in the device list if properly installed. Try to press Fn key + Esc key at the same time to enable/disable webcam.
but what i just described there kinda seemed like you did it already. if its a usb webcam. unplug it and plug it back in. also check there website for the drivers. if you did fn and esc and u turned it off then it wont show up in the device manager.
Mar 16, 2011 | Computers & Internet
The built-in camera isn't working.... whenever it is click to use, the pop-up window opens with the message no camera found.... i already re-install the application but still the same. how can i fix it?
Please find the below steps to access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume. Increase the notebook volume level by pressing the Fn+PgUp keys.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Suyin) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 26, 2010 | Acer Aspire One PC Notebook
Webcam not working
Try reinstalling the WebCam driver, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> install Application & Drivers> Select the appropriate WebCam (Suyian or Chicony) and install it and restart the computer.
If the camera is still not working then can perform a factory restore, to do so follow the below steps: Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 26, 2010 | Acer Aspire 5315 Notebook
LG smart cam not work
Just press FN+F10. It'll activate the webcam.
Aug 12, 2009 | LG X-Note LM50 Notebook
LG E 500 webcam not working
I know this sounds a bit obscure but try following these excact steps.
shut down the computer.
remove battery and ac
reinsert ac
turn on computer and imediatly press F2 several times to access BIOS.
go furthest right in the menu and choose to "set default valuse"
save and exit.
boot up computer completly
shut it down again
insert battery
boot up
try the YouCam software wich should now activate the camera and make the led light up orange.
(i actually had a computer of the same kind you have for the same problem yesterday, and i found this solution wich worked here on fixya)
May 29, 2009 | LG E500 Express Dual Series Notebook PC
MSI wind U100 built in webcam
Try to press FN key together with F6 to makes the webcam works
Mar 27, 2009 | MSI Wind UmNotebook
NOT FOUND WEB CAM CHECKED YOUR PC CAMERA
you should be able to get it back easily. by hitting Fn+F10 you can activate the smartcam again.
Feb 25, 2009 | Computers & Internet
WEB CAM
just simply do fn+f10
Aug 16, 2008 | LG X-Note LM50 Notebook
Computers & Internet Logo
1,009 people viewed this question
David Payne
David Payne
