Question about Motorola Mobility Moto Q
My MotoQ 8 restarts even on the slighest touch on some keys on the keypad. It restarts almost every hour. The date goes back to year 2005 and the history of calls/message after that goes for a toss. I changed the battery, still the same problem persists. Any suggestions
    President:
  • 1,223 Answers
It is typically a software problem it seems like have u tried resetting the device if it helps other wise update ur ROM from www.motorola.com ur data will be lost pls rem backup it first
let me know if i can help u more
Posted on Feb 27, 2009
My DSC Wt5500 Alexor Wireless keypad not keeping correct time even after changing batteries. Is there something in the programming I need to do to get it right? Thanks!
I am assuming that the keypad was successfully enrolled? Try to reprogram time. Time should be coming from the main unit and not the keypad itself.
*6
Master Code
24 hour time (ie 2pm= 1400)
Date Format mm/dd/yy
Keypad should confirm successful entry by beeping rapidly three times
press # a couple times to get out of programming
After exiting programming the display should come up within 30 seconds or so displaying the date and time before it goes back to sleep.
Apr 12, 2015 | DSC Wt5500 - Alexor 2-way Wireless Lcd...
My frigidaire model # ffmv164lsa microwave oven keypad does not seem to work. Some times it goes on by itself. Or if you unplug it 05 will go on. Cant set the clock. or if touch anything nothing happe
The answer you seek is to replace the keypad. Your unit is Stainless for you would have to replace the console as one piece part number 5304477377 I this helps. Good Luck
Apr 19, 2014 | Microwave Ovens
My 2005 harley sporster 1200 keeps on stalling after an hour or so of riding. the odometer goes first then it putters for a bit and dies. and when i try to restart i can't even get it to roll over
Hi Sa_larade, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Apr 15, 2012 | 2005 Harley Davidson XL 1200 C Sportster...
How can i set the date n time in Panasonic TX-TGA542AL cordless phone?
This is how to set date and time on panasonic KX-TGA542AL.
Press the "Menu" key.
Use the up and down arrow keys to select "Date and time." Press "OK."
Enter the month, date and year using two digits for each on the keypad.
Enter the hour and minute in 12-hour clock format using the keypad.
Press the asterisk (*) key to toggle between "AM" and "PM."
Press "OK" and then "OFF."
Regards
Jul 12, 2011 | Panasonic KX-TGA560 Cordless Expansion...
How do I change date and time?
Step 1 Press the FEATURE key followed by **8463 Step 2 Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options: Step 3 Select CHANGE - the display will show the following options: Step 4 Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. Step 5 After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same. If you want to change the date, select NEXT. Step 6 The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005). Select NEXT, and repeat to change the month and the day. Step 7 Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 30, 2011 | Nortel Norstar 16-Line PBX Speakerphone
Motorola q randomly restarts and my text messages erase
I can help you with your Motorola Moto Q randomly restarting problem.
What has most likely happened is that the firmware of your phone has become corrupted. When this happens your phone will act erratically, freeze, or no longer finish (or even start) its boot sequence.
This is a very common situation with many phones; also with MP3 players, GPS devices and cameras.
The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.)
If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times.
My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone.
I hope that helps.
_________________________________________________
Motorola MotoQ Manual Download
Motorola MotoQ Update Manual Download
Motorola MotoQ Verizon Firmware Update Download
May 12, 2010 | Motorola Mobility Moto Q
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Cannot set time and date,
My Tocco Ultra works by just going into Menu, Settings, Time and Date then scroll up until you get the Time window. Tap on the time window and the hour is highlighted for you to type in the hour, then when you've done that the minutes get highlighted so you can type them in. then you need to tap on Save at the bottom. Hope it works for you
Jun 09, 2009 | Samsung S8300 Ultra Touch platinium-red...
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Time clock shows the date 3/8/2009, should be 3/9/2009
Right click the clock on the desktop, and choose adjust date/time. Adjust it, and enjoy.
Mar 09, 2009 | The Times ROYAL TC100 TimeMaster Time...
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
