Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Wont' turn on! Power button lodged?
Hi - I love my Canon but now the poor thing won't turn on (and it's not the battery or the lens, but the actual button) I think the button might have a loose screw or something because if I keep pressing it, at times it would turn on, but then it takes ages to turn it off too.
What should I do? Anyone else experience this problem?
Thanks!!!!
    Scholar:
  • 57 Answers
It sounds like either the power switch itself or the connection between the switch and main board could be faulty. You would most likely need to have a service centre replace the power switch circuit to rectify the problem. Best of luck!
Posted on Apr 14, 2009
When i turn my camera on it makes a grinding noise, displays an camera with red x
Power is fine, your case sounds like a jam or an obstruction by a foreign object in the lens (lodged between the extension barrels of the lens. This is an extreme situation and you need professional help, unless you are good at fixing things yourself.
Nov 03, 2015 | Cameras
Canon Powershot A495 Wont power on using the ON/OFF button
The problem is short on playback button due to humidity (see differences between the buttons on foto no.1), wich can be removed mechanically using a pin and making two holes(inlet/outlet) at the side of the button where no wiring running(!) and with a hypo carefully shooting air beetween the foils. It is useful to lift up little bit the spring button from the bottom foil to remove the short. A hair dryer can be also helpful to dry out the space between the foils. Please check the fotos and link too.
The camera will not power on by battery insertion when short is over. To protect buttons against repeted defects I used an adhesive tape to close the openings on the top of the buttons.
Canon Powershot A495 Wont power on using the ON OFF button page 2 General...9475eddd-e98e-40e1-9ff5-48f2b88aa22a.jpgimg_3172a-qpgfxpscyuxnmpq5faoemdbh-2-2.jpgimg_3180a-qpgfxpscyuxnmpq5faoemdbh-2-3.jpg
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
I have a Canon EOS digital Rebel XT. I was taking photographs the other day when suddenly it stopped working. The camera still turns on and all the buttons are functional, but it won't actually take a...
I hope you have solved this problem if not there is two things that have happened to me one was that I had unlocked the lens and it turned a little which shut off the communications between the camera ad lens. The other is where the gold contacts between the camera and lens became slightly dirty with a hazy this is easily fixed with a DIY. using a pencil eraser gently polish the contacts between the camera and lens both sets of contacts, be careful not to get dirt into the camera or lens when you are doing this. Don't use a puffer or any air.
May 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Camera wont turn on: lens error, restart camera
Your problem is common to that model and actually to most of camera models. Usually it has foreign materials interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. It's also possible that the camera has been powered on, but the lens had been blocked preventing its extension which eventually damaged gears or other parts. You should also check if your battery has enough power to supply the lens mechanism, easy way to find out is to use a new charged or brand new battery.
If you are still under warranty, I suggest to bring you camera to the store or service center. If not then here are some things that you can do to try to correct it. I hope it will work for you.
Regards,
Jeep Brainy
Aug 11, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Codee error 99 ??
hi,
I do not know if this is going to be of any help. I was actually reading about this error code 99 in canon, and bumped into a forum, where people had share their experiences. You can give it a try. But if your camera is still under warranty, it is best to ring technical support.
"ERR 99" is a general error code displayed by the camera when the camera knows that something is not working properly, but not exactly what.
This error is typically associated with lens communication or shutter mechanism issues. To isolate the cause of the issue, we suggest that
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the
camera body.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
Hope this helps !!!
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
My Power button isnt working
There could be several thing that could cause this problem like a bad lens. the battery might have to be left out of the camera for 24 hr to discharge the battery, a damaged main board. a defective power button. try taking out the memory card to see if that fixes it. repairs on this unit can start any where from 65.00 and up. goto www.digitalcamrepair.com if you need repair service.
Dec 09, 2008 | Canon PowerShot SD1000 Digital Camera
Wont power on...
If you're certain the battery is fine, the next thing to try would be the following. Pay particular attention to the little switches on your doors:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
And if those techniques don't work, next thing to try would be fixes for a lens error (you mention it powers on and off. This is sometimes symptoms of a lens error):
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 20, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Nothing apparently wrong; acts like battery's dead
Here are some simple things to try first for a camera that won't power on:
Nov 24, 2007 | Canon PowerShot S60 Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
133 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
