Question about Casio FX-115ES Scientific Calculator
About calculators in calculators i have seen green colour flow lines .what are thjey and how it works
  • Casio Master
  • 7,993 Answers
The numerical solutions to certain differential equations can be sought graphically. Representing the flow lines in a plane can help visualize the family of solutions.
Hope it helps.
Posted on Sep 01, 2009
  • k24674 Sep 01, 2009
    Sorry I was barking at the wrong tree: I posted my answer but for the wrong question.
  • 76 Answers
This happens bcoz of the screen...so this common...its bcoz of the impression on the screen...u can better open it and clean the screen frm inside properly in a soft cloth...then u can use it forever...dont worry!!!!!
Posted on Jul 24, 2009
Diagram for multi plug, elkavox 83 generater to accordion
one wire coloured red is connected to the live line(soldered)
second wire blue in colour is connected or soldered to the neutral line.
third wire coloured green and yellow is connected to the earth line.
Jan 27, 2012 | Electrical Supplies
Tip
SONY TRINITRON ONE COLOUR PREDOMINANT SCREEN
Sony Trinitron sets are of CRT [Caothde Ray Tube] types. The common fault seen in these type of TVs are any one colour predominant on screen wih sound OK. Either red, blue or green colour with some thin horizontal lines at about an inch apart will be seen on the entire screen. This is totally a display card problem, which can be seen pluged onto the picutre tube neck. There are three electron guns for every picture tube, which emits red, blue, and green beams, which in turn illuminates the phosphor on the screen to get that colour. If no emission from all guns, results in a blank screen, ie black screen without any disply at all. The three colour beams together produces proper coloured picture what we see on screen. These three gun's terminals are brought out by pins of the picture tube outside to which video signals are given in appropriate proportion to produce a TV picture. Normally, all these three pins are biased with a voltage of about 170 to160VDC+ve. Take one colour gun, as an example and and let me describe the problem.
Let it be a green gun. These guns are called cathodes of the picture tube. If it gets a voltage with respect to its grid, it will emit electrons according to the voltage applied to it. This is a negative process, that is, as the voltage at this pin drops, its emisson incresses and vice versa. If the emission increase, the colour with respect to that gun also will increase and gets predominant at the screen. So when we see a green predominant screen, there will be less voltage at the green cathode with resepect to the other two. If red colour is predominant, the voltage at red cathode will be less than the other two. If blue colour is predominat, the voltage at the blue cathode will be less than the other two.
We must find out the reason for this fault first. Assume that your Tv has a red predominant screen with some thin lines across it, at about one inch apart of the entire screen, it is clear that the the red cathode voltage is very lower than the other two. the main reason for this fault, normally seen in most of the Sony Trinitron, are loose soldering points either to the picture tube base socket or the resistor connected between the red drive transistor's collector point. Resoldering the most of these points on the base card by applying a little more solder will rectify this probelm. Other possibility is shorted video output transistor of that cathode. A direct short [collector to emitter] of these transistors will drop volatge to very low at that respective cathode of the picture tube, and that colour will be pridominant along with lines. Replacing the transistor will solve the problem. In some cases, the resistor connected to that transistor may have blown out. If so, it should alo be replaced. Whatever the case may be, voltage at the respective cathode that emits colour will be very low with respect to the other two. Find out the reason and rectify it. You can compare the voltages of the other two cathodes with respect to the faulty colur cathode. Cathode pins will be marked on the base card, and can be identified. It is best to pull out the base card from the picture tube neck and place it somewhere a safe place without shorting it with other parts of the TV. You can measure the voltages of these points very easly, without fearing the damge to the picture tube. After all are found Ok, replug the base card and switch on the TV. The set will be alright. In rare cases, chroma IC also can be a reason for this fault. if it is faulty, after a short period after switch on the TV, the IC will overheat and shutdown the entire system.
on Mar 21, 2011 | Televison & Video
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
Coloured lines appear when I switch on the camcorder
Hi....
Try another output cable and make sure your rectangular A / V connector isnt dirty of damaged.
Also, try another TV just in case
I work on these ALOT and havent seen coloured lines yet.
Mar 24, 2009 | Sony PlayStation 2 Slimline Console
Colours split and vertical bowed green line at to and bottom of s
This is a convergence problem that can be either poor solder connections at the convergence ICs or defective ICs. If you can solder and feel comfortable working inside the set where there are potentially dangerous high voltages, update this and further details and instructions will be provided.
Thanks,
Dan
Dec 12, 2008 | Samsung HLN5065W 50" Rear Projection...
Purple and green scrolling lines
This may be a mechanical or electronic problem that is dealing with the sync of the colour wheel. There is basicly no colour lock. This may be the replacement of the associated circuit board, or the motor assembly or the colour wheel.
The link below is describing about how DLP technology works. They are relating to a front projection type. With the rear screen type, the basic technology is very much the same for decoding the pictures from the TV signal.
http://www.hometheaterhifi.com/volume_9_1/plus-piano-projector-3-2002.html
Jerry G.
May 02, 2008 | Samsung DLP HL-P5663W 56" TV
RCA DLP HDTV POOR COLOUR - TOO MUCH GREEN
Hello:
It sounds like your light engine needs replaced, should be around $400.-600. depending on who does it. I have seen the lamp cause similar symptoms but not that likely.
Feb 29, 2008 | Televison & Video
Screen problem
setting that change the language and font sige and try
Jan 04, 2008 | Texas Instruments TI-89 Calculator
Colour is wrong
Yes seen new color cartidges bad. Machine new should be under guaranteed also if cartridge does not work...
Dec 30, 2007 | Office Equipment & Supplies
Color shift problem with 330GS
This is because the RGB filters in the camera are not perfect, and there is no one "green" colour. The green pixels pick up a wide band of colours, and are somewhat sensitive even to red and blue, especially near where green shades into red.
Sep 08, 2005 | Pentax Optio 330GS Digital Camera
Casio FX-115ES Scientific Calculator Logo
97 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
