Question about Ricoh Caplio G4 Digital Camera
Caplio g4 - Laptop Wont read my camera
I have installed the software correctly but when I connect the camera to the laptop via the USB cable an error message appears saying:
Unable to connect to the camera.
Check that the camera is correctly connected to the PC.
I have Windows Vista Home Premium.
Please help.
  • jameshanna18 Mar 02, 2009
    Thank you - problem is solved. Much appreciated.
You need a compatibility patch for your camera to work on Vista. Get it Here:
http://www.ricoh.com/r_dc/os/win-vista.html
Posted on Feb 28, 2009
I need to conect my camera sony dsr pd177p to my laptop how can i transfer videos from camera to laptop plz tell me
The hardware and software for this are available from retailers such as Maplins or Radio Shack, or can be purchased via Ebay.
Jun 25, 2016 | Sony Dsr-pd177p Pal Dvcam Camcorder
My Toshiba laptop wont download pics from my Canon camera - it used to be fine but wont do it now!
Does the camera appear in the device manager?
right click my computer select manage
on the left side select device manager
look on right side do you see your camera and does it have any ? or ! marks?
Aug 09, 2008 | Cameras
Hi, I have installed a signet QV 3063 camera system. The software CD doesn't have any software installed on it and hence my laptop doesn;t see the HDD when I plug it in via a usb cable. I have downloaded...
Have you tried downloading it or using web-based app? Seems this may be a good place to start:
http://software.ddcode.com/signet-qv-3063.html
Jul 14, 2014 | Cameras
How to connect pc with micromax Q5 mobile. I am using vodafone prepaid connection.
you connect via a usb cable or bluetooth which is a wireless connection. if you have tried connecting with a usb cable, what happens? If the device cannot be seen or recognized by your pc the most common reason is that you dont see a device you plugged in is that you dont have the proper drivers installed on your pc. See what error meesages you get, and troubleshoot! Are you saying your internet connection on your PC is via vodafone usb dongle? This should not affect your ability to connect a mobile phone via a usb cable which should work without being connected to the internet. Its all a question of hsving the correct drivers, but some software wont work with the dongle software, which has to be uninstalled. Troubleshoot for the correct drivers them get technical help from micromax
Dec 27, 2010 | Computers & Internet
USB upload error from Panasonic DMC-TZ4 to my laptop (Thinkpad T)
Are you trying to copy your photos off the camera, or use it as a webcam?
If you are trying to copy photos, then make sure the camera is in the correct mode, eg: playback mode. if the problem still occurs then try a different USB socket on the computer. If that doesn't work then possibly the USB socket on the camera is damaged (this is a common fault). I would suggest getting a SD card reader that stays connected to your computer full time, take the SD card out of the camera and plug it into the SD reader. That is a more reliable solution.
Sep 27, 2009 | Panasonic DMC-TZ4 Digital Camera
Trouble uploading photos from my camera.
you need the driver for your camera so that the computer can read
May 29, 2009 | Fuji Finepix Z20fd Digital Camera
Not responding to my laptop
The most common cause associated with the PC not detecting the camera is due to the fact that either the devie drivers have not been installed, or are corrupt. It is important to thoroughly read the Software Installation instruction manual as with some Cameras, the user is required to connect the Camera via the USB cable first, then insert the CD that came with the camera and then install the software and drivers. With other Cameras, the reverse is necessary, eg., you are required to install the software first and then connect the Camera via the USB cable. My experience has convinced me that even though Camera manufacturers recommend one or other of the 2 methods mentioned above, for whatever reason, sometimes the drivers just don't get installed. This may be due to things peculiar to your own pc system or conflicts with other software on your machine which prevent successful installation of the camera software or drivers. If this is the case, then you can access Device Manager in your PC and scroll down to USB Serial Bus Controllers and check to see if the USB and other drivers are installed. In most cases if the software has been installed but the drivers are not, or are corrupt, this will be highlighted in Device Manager with a Large Yellow ? (question mark) From there you have the option to check if the device drivers have been installed and also if the device is reported as working correctly. You may then engage the help of the Hardware Wizard to uninstall the drivers if they are corrupt, or install them if they are missing. Whichever is the case, it is usually necessary to restart your PC so that it can detect the camera when it has rebooted up. To locate Device manager on XP > click on Start > then right click My Computer > next left click Properties from the drop down menu > and then from the Sytem Properties Window which comes up, > left click on the Hardware Tab > then left click on the Device Manager Box and you're there.
Sep 21, 2006 | Canon PowerShot A410 Digital Camera
Ricoh Caplio G4 Digital Camera Logo
240 people viewed this question
Top Ricoh Cameras Experts
Greg Cann
Greg Cann
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
