Question about Bosch Washing Machines
Bosch WFF2000 pre wash light comes on during cycle. Expensive??
I have a Bosch WFF2000 (recon. exchange) Had for 9 years, so I'm not complaining. However, the prewash light comes on after somewhere during the final wrinse with full water. This stops the cycle and I have to turn the machine off and turn the dial back round to a similar position. When I turn the machine back on the pre wash light dissapears and it completes the wash cycle.....most times. This is an intermitant problem. I suspect this is an expensive problem to fix and i'm gonna have to let this dependable machine go???
3 Suggested Answers
  • 14 Answers
SOURCE: bosch wff2000. goes through program
it sounds very much like the carbon brushes in the drive moter. the best way is to remove the motor and then you can also check the commutator for wear as well. model no and serial no needed to get spares, sometimes moter type.
Posted on Oct 06, 2008
  • 523 Answers
SOURCE: It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Posted on Jun 23, 2010
Not water comes into Bosch dishwasher?
Assuming you have verified water is actually getting to water valve, most likely water valve is the problem and needs replacing.
Sep 10, 2017 | Bosch Washing Machines
Bosch WFF2000 machine selected 60deg wash ,it clicks from main wash position on dial a couple of clicks then trips the whole house.This issue happened very suddenly.What could it be
agitator motor has broken windings causing a short when it tries to start. This trips the breaker in the main panel. If not repaired you could have a fire and that is why the breaker blows
Jul 23, 2016 | Bosch Washing Machines
I've a 97 bosch wff2000, washes, drains but will NOT spin either after main wash, rinse nor does it do the final spin. Had it from new, so definately can't complain. I've just replaced brushes...
Try disconnecting the small bore hose from the pressure chamber it could be the switch has stuck in the on position in which case the pressure chamber is blocked (the chamber is at the other end of the small bore hose )
Mar 28, 2017 | Bosch Washing Machines
Bosch Dishwasher model SHU66C06 doesn't enter wash cycle
this sounds like flow sensor failure,it it fails machine will either not fill up or fill and drain without washing its a cheap part to replace and is fitted downstream of inlet valve behind l/h/s side panel either attached to inle hose or heat exchanger.
Mar 03, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
What is the life expectancy of Bosch front loader (under counter)? Making loud noises during wash - not spin - cycles. Worth repairing?
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Dec 27, 2010 | Bosch WFK 2401
Jun 23, 2010 | Washing Machines
No user's manual for Bosch WFF2000
Give this a try! This might be just what you're looking for, but unfortunately, there isn't a model number provided for the download.
If that doesn't give you what you're looking for, go to the link below and enter in your information and Bosch will contact you directly and should be able to provide a link for a downloadable (free) manual for your washer.
Another possible source, although I've not used them before is the following link. You'll need to provide your information for them to send you an email, but not sure if the provide free manuals, or charge a small fee for their service. There is no cost to at least enter in the search parameters to find out.
Hope you find this Very Helpful and best regards!
Oct 16, 2009 | Bosch Washing Machines
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch wff 2000 washing machine - won't spin/drain
How did you solve this problem. I have the same problem. Kiran
Mar 09, 2008 | Washing Machines
Washing Machines Logo
88 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
