Question about HP PSC 2210 All-In-One InkJet Printer
Clear carriage jams
I can print a maximum of 2 ages and then get an error message to "clear carriage jam". But there is no carriage jam. I have to unplug the printer and then re-start.
    Sergeant:
  • 199 Answers
Use some lubricant or oil (minimum) for cartridge rail
Posted on Feb 27, 2009
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
C6180 clear carriage jam
Change ur categer and clean ur inside the printer,and delete old documents.
Jul 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Carriage jam on HP Photosmart 3210 Printer
most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
Dec 13, 2008 | HP Photosmart 3210 Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
204 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
