Question about HP Pavilion dv4000 Notebook
I have a HP Pavillion DV4000 and it does not charge
  • 2 more comments
  • maykov1587 Feb 27, 2009
    I apologize for earlier confusion, I'm pretty sure its not the battery, it might be the actual power connector on the laptop itself because the power light does not go on when I plug in the power supply, I also have a newer Compaq that uses exactly the same power supply which I tried as well so I know the power supply is probably fine. But if it is the actual connector on the laptop, is there anything I can do?
  • maykov1587 Feb 28, 2009
    I leaned all the contacts, on the battery and on the computer. I plugged in the power adaptor without the battery at first to make sure that the battery wasn't causing the problem, and I got nothing, then I put the battery back in - same thing, no power what so ever. I even tried to take out one memory stick and see if it will work, then swiched it with the second one and tried plugging it in, nothing works, I just don't know what else it could be if not the socket any more. Maybe it shorted out or someone was not careful when the laptop was plugged in and ripped the plug out of the socket, thus damaging or disconnecting the socket from the motherboard itself. I really wanted to take a look at that connection, but after I took out all the screws, the back panel still won't come off...so I'm not sure how to get to the actual power socket and see if its connected to the motherboard. Thanks a lot for all your help.
  • Anonymous Mar 01, 2009
    My Hp pavilion dv 4000 does'nt turn on or charge and i got it fixed for like the third time, worked for a few weeks and then it happened again. Is it the battery,charger or something else please help!!!
  • Seabee Tim May 11, 2010
    Does the computer run OK plugged in? If so, sounds like a faulty battery. Batteries don't last forever, usually they'll last the lifetime of the PC, but some PC's are older than others...
    President:
  • 1,223 Answers
Pls check if it runs ok during power supply AC and also check Battery contacts on both side laptop side and battery contacts see if rust or residue is sticking there try to scratch it out by some rust removing cream or something normally it happens other wise if the adapter supply is ok AC one then ur battery is faulty try replacing it there is a battery checking utility on HP support software try it , i think it will help u cjeck the batt
pls rate me if i fixed it
Posted on Feb 27, 2009
  • Shoaib Rais
    Shoaib Rais Feb 27, 2009
    actually it is not suggested to replace the connector side of the laptop , i was asking for the battery contacts are they ok pls remove the batt and see the contact from where batt passes current to the notebook actually some notebooks does not charge without proper batt connection pls check them and tell me u are sayin charger is ok , battery is ok how can u say batt is ok and for the socket at laptop side there is nothing to replace in it and it is not recommended as well kindly trouble shoot and tell me if i can help more
  • Shoaib Rais
    Shoaib Rais Feb 28, 2009
    actually if RAMS dont work
    Power Supply is ok
    Battery is ok pls check on some meter both supply and battery for volts
    try ur faulty laptop supply in the other compaq laptop if it works there then
    i am getting a feeling that ur mother board is faulty it is not taking up power and thus not supplying power to any component
    pls let me know if i can help u more on this
Is there any sata slot available on HP Pavillion dv4000 laptop, i mean can i install a sata hard disk in my hp Pavillion dv4000 laptop?
hi this depends on the age if it is older than 3 1/2 year old approx, then you maybe able to put one in, other than that the easiest way to find out is to take the old one out, just look at the back end where it connects to the board, if it has pins in the back its ide if it has just a line of contacts then its sata...hope this helps
Jun 05, 2010 | HP Pavilion dv4000 Notebook
How to remove battery on motherboard on hp pavillion dv4000
hi
which bettery u wnat remove
if u looking to remove cimos bettery then in this model you have to open from the keybord penal if you well noon in this then only
or go to technition
May 15, 2010 | HP Pavilion dv4000 Notebook
HP Pavillion DV4000 notebook display shading
It sounds very much like an inverter issue. The inverter sits under the lcd screen in the screen plastics. It is replaceable, but obviously there is a danger the screen may get damaged.
Nov 21, 2009 | HP Computers & Internet
I cannot pair my HP Pavillion dv4000 Notebook and
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your device. Choose the headset, and then at the next page, choose your device. Moving your mouse over each step will change the picture to what you should be seeing at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 29, 2009 | HP Pavilion dv4000 Notebook
HP Pavillion dv4000 is stuck with a 'disk read error'
try with Disk Manager so Format with Low Level Format...run in under DOS
Oct 23, 2009 | HP Computers & Internet
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
Pavilion dv4000 microphone
sorry no build in microphone use ext....
Apr 28, 2008 | HP Pavilion dv4000 Notebook
Replacement part
Page 57 of this manual can tell you your part number.Let me know how you make out.
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Dec 11, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
223 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
