Question about Sony VAIO GRT170 Notebook
Hotkey utility not working Sony VAIO GRT150 PC Notebook
  • obturatorfor Apr 04, 2009
    function hot key does not work
  • ci_ling May 11, 2009
    PCG GRT 170 Hotkeys also are not working, even the Volume Key below the Touch Pad.
    Scholar:
  • 154 Answers
You can get the Hotkey utility driver from the link below
esupport.sony.com
It will give you the driver's list and you can get the hotkey driver under the
Notebook Control and Utilities - 2 file(s)
Posted on Apr 11, 2010
Fn keys working hotkey
Normally this issue happens after installing the a system related software or an upgrading/ reinstalling a operating system. Please read the below steps very carefully and follow the procedure below to resolve the issue.
Download and install the following application updates in the exact order they are given.
IMPORTANT:All of the listed application updates are available online. Software and driver updates for your Sony product are available online.
  1. Audio Driver (most recent)
  2. Video Driver (most recent)
  3. Sony Firmware Extension Parser Device Driver
  4. Sony Shared Library Update
  5. Sony Setting Utilities Update
  6. VAIO Event Services Update (If available)
  7. VAIO Launcher Software (S1/S2/AV Buttons)
If the above order does not work, try the order below.
  3. Sony Programmable I/O Control Device Driver Utility or Sony Notebook Control Driver
  5. Sony Utilities DLL Update
  6. Sony Event Service (If available)
  7. Sony AV Mode Button Utility (If available)
Reference: The function keys do not work
Jan 11, 2014 | Sony VAIO VGN-CR510E/L Laptop
Hi. I my fn keys no longer work in the sony vaio FS285B
The problem is that the Fn Hotkey Utility breaks when XP SP2 or some other patch goes on. You can fix this by using the Vaio Recovery Wizard. Click on it, then Proceed With System Recovery, Custom Recovery, Application Recovery. Select HotKey Utility then Repair. It takes a reboot and works after that.
This is a skill you will get good at with a Vaio as it seems that every driver update or patch from Microsoft will break something.
I hope this helps!
Sep 23, 2011 | Sony VAIO VGN-CR115E/P Laptop
I can't use FN+F5 to adjust brightness. From Sony Website, I know that in need of set up Sony Share Library for Win XP and HOtkey Utility application. I have already set up Sony Share Library for...
Hi.
In order to use the Function keys, download and install the two Applications mentioned below:
1) Sony Shared Library:
http://s02.download.sony.com/US/pc/SOASSL-10133900-US.EXE
2) Sony Notebook Utilities:
http://s02.download.sony.com/US/pc/SOOOTH-41300000-XP.EXE
Once you have downloaded both the Applications, install them and restart the Computer for the settings to take effect.
Once you have restarted the Computer, you should be able to use the Function Keys.
Hope this helps.
Please feel free to contact for further assistance.
Thank you.
Suresh
Aug 06, 2011 | Sony VAIO VGN-NR160ET Notebook
I have installed win7 ul on my sony vaio vgn-sr390 & my hotkeys dont work now I couldnt find any software to install for that Please send me what should I do
http://www.laptopdrivers.net/download/sony-vaio_vgn-sr_390_drivers_for_windows__7_ultimate_64-bit.htm
THE ABOVE SITE HAS ALL YOUR REQUIRED S/W. DON'T FORGET TO INSTALL Control and Utilities S/WREGARDS.
PLZ. RATE THIS
Jul 05, 2011 | Sony Vaio SR-390 C2DUO 2.4GHz P8600 3GB...
I can't find the the hotkey utility application from the sony web site.model is VGN-NR160E. Tks !
To enable the Function keys in the Computer, it is required to install VAIO Event Services. In older Computers, the application was called Hotkey Utility and in the newer Models, VAIO Event Services is used to enable the Function keys. You can download the VAIO Event Services (Notebook Utility) from the link below.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR160ET&upd_id=3262&os_id=28
Good Luck
Jul 16, 2010 | Sony VAIO VGN-NR160ET Notebook
My fn button doesn't work
WHAT TO INSTALL?
To get the Hotkeys working your Vaio laptop requires THREE different components/sets of software installed, these are:
'Hotkey drivers'
'Sony Shared Library'
'Sony Utils'
Once you install these three components & restart your Vaio laptop your Hotkeys should be working. These are all unobtrusive files that will only enhance your Vaio machine however alternatively you can install Sony's Powerpanel or Batteryscope programs to perform the similar features.
Most these files are written for specific Vaio models however there is some overlapping and files from similar Vaio models may work with your own laptop.
WHERE TO FIND THESE FILES?
There are various online resources relating to this topic however the best place to find these files is the one below.
ftp://ftp.vaio-link.com/pub/VAIO/ORIGINAL
Using that site, find your model number & download the relevant 'Utilities' file. You might also find useful the link below, which may help with this task and/or others (including RAM upgrade advice etc)
http://support.vaio.sony.co.uk
It took many reinstalls to work out the order and what programmes needed to be installed to get the hotkeys working & I purposefully took hours doing so, noting each step I made so this guide could be written and save time for others.
Aug 06, 2009 | Sony VAIO VGN-FS742/W Notebook
Battery problem, hotkey problem
remove the battery then insert again,..
Jun 06, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Reformatted HD , Function keys not working
I don't think so. It could be a hardware problem. Take it to the service center OR if you have any diagnostic utility scan for hardware fault.
Apr 09, 2009 | Computers & Internet
Keyboard volume control
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFJ270B&LOC=3
There is all the drivers for your computer. The hotkeys will be listed under BIOS
Feb 07, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony VAIO GRT170 Notebook Logo
871 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
