Question about Jane Powertwin Jogger
Don't know how to put Jane powertrack seat into
Don't know how to put Jane powertrack 360 seat into any reclining position, is it possible? (this stroller was given to me!)
There is a small metal handle behind each seat, pull it up while you move the seat into the recline position you want - rear seat has four positions, front seat has two. :) Jan.
Posted on Nov 14, 2009
Does the jane matrix car seat fit on powertrack 360 frame ?
Provided that you have the Matrix with the light grey plastic handle, yes. You would require these adaptors to attach the Matrix to the chassis.
http://www.johnstonprams.co.uk/dynamic/viewitem.php?item=C3718
Hope this helps.
Apr 23, 2011 | Baby Gear
Hi do you know what the upper weight limit is for a "Jane 360 pushchair is"? 3yrs 6 mth Son is 18kg and has to got to hospital for repairs; will be discharged with approx 3 kg of plaster cast!! don't...
Approximately 20kg is said to be the upper weight limit or four years old depending on how comfortably they fit in the chair.
This answer is for the Jane Powertrack 360.
Aug 17, 2010 | Jane Toys
Jane powertrack 360 - front disk brake missing
I would suggest that you visit www.johnstonprams.co.uk and contact them as they are the best people to assist you, good luck!
Hope this helps.
Feb 21, 2010 | Baby Gear
Jane Powertrack 360 Manual
Hi Maureen, if you contact info@jane.es they should be able to either post the manual to you or send you a downloadable PDF.
Sep 15, 2009 | Baby Gear
Fitting jane carrycot in car
To fit the Jane Capazo Carrycot succesfully, this depends on your car. It needs to use two 3 point seat belts. 2 point seat belts don't work. Plug in both seat belts, and pull the lap belt part through the red catch on both side. Pull as tight as you can. To make car seat fitting more secure, try placing a slip mat like the Sunshine Kids Grip It or Super Mat underneath to hold it in place. These are all crash tested and safe.
Mar 27, 2009 | Baby Gear
Fitting jane powertrack 360
Are you attempting to place the car seat onto the stroller? If so then I can help as I have a powertrack 360 with the matrix car seat.
Jan 03, 2009 | Jane Powertwin Jogger
Instruction manual missing
If you contact www.johnstonprams.co.uk they will be able to help you get a copy.
I hope this helps.
Nov 29, 2008 | Baby Gear
Jane powertrack 360
There should be two black triangular attachments with little red handles that go on to the sides of the buggy. You use the grey handles at the end of the side arm of the buggy to pull the rear locking pins backwards and then slot the attachments on to the front pin with the red handle pointing forwards. Release the grey handle and it will lock into place. When both sides are in place, simply drop the car seat on to top of the two attachments. Removal of the car seat is by using the red handles.
HTH..
Nov 10, 2008 | Jane Powertwin Jogger
Jane Powertwin Jogger Logo
350 people viewed this question
Top Jane Baby Gear Experts
Shehu Pro
Shehu Pro
john h
DROPNDEAL
DROPNDEAL
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
