It can play sound
But cant play sound when the power botton is switch on
Cant play music
hold the record button, and power botton together to enter the device in reovery mode and then connect to computer. 16mb format file wil be shown therein. type sansa.fmt and disconnect from pc. it will get formatted itself and then try reloading music files. and dont forget to slide the lock button before the procedure stated here. it should work. beware of formattng if u dont want to lose ur data inside it. try to scan for virus and if not solved then format.
Dec 12, 2013 | SanDisk Sansa Clip Zip MP3 Player
Sony music hi fi system mhc-gzr88d show only demo not started
If only demo mode is playing,it's mean set is in standby mode.Normally
in standby mode it can't be operated.You have to power on the set by pressing power botton during demo mode.Once it gets power on,it will
start to work according to user required function.If the set not get power on after pressing power botton,then it's an electrical problem
and need to visit your nearby repairing centre.
Oct 17, 2012 | Sony MHC-GZR88D USB MINI DVD HI-FI SYSTEM...
Cant get demo off on a samsung tv LE32C450E1W
Try doing the same thing, except instead of holding the menu button, hold the power button
Aug 29, 2012 | Samsung Televison & Video
I cant seem to be able to turn it on because i cant find the power botton.
Hello!
Many Mp3 players often times have no power button, or a On/Off button. Although they probably should, many companies allow buttons to play multi tasks in the ever increasing need to save space.
Most times, pressing the play button, or holding the play button (signified by a right facing triangle) is used to start the mp3 player.
Ipod's do not have a "on?off" button either, you can simply press any button to make it start. holding the play button will allow it to go into a power save mode and "shut down" as well.
There is often a "lock" button you may have to slide or press in order to get it to turn on. This button is there so to no accidentally turn on the mp3 player when you dont need it, and waste battery life.
Hope this helps!
~Daniel.
Dec 28, 2010 | Audio Players & Recorders
My clarian car stero will play the cd player while
It sounds as if the power leads are not connected properly.
Make sure the memory lead is connected to a constant 12+ volt source, and the switched lead is connected to a 12+ volt power source that is controlled by your ignition switch.
Aduz
Feb 24, 2009 | Car Audio & Video
Power botton not responding
If it's not ejecting or responding to any of the buttons on the unit, or the remote, but is able to play a DVD, the display microprocessor(computer) within your Harman is damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 22, 2008 | Harman Multimedia HS 300 System
I just answered this question. Again, for more information, please visit my website at audioserviceclinic.com. Thank you.
My cdj mk2 screen wont light up or play
sounds like a power supply to lcd pcb is down, if you havent had it repaired you can send it to us.
Regards.
http://www.audiovisualservices.info/
Aug 01, 2008 | Pioneer CDJ-1000 CD Player
Bad botton panel
jgfran,
You can try powering the unit off, unplugging it for 15 minutes and see if controls return.. It's a long shot, because what you're describing is usually the Eeprom failure, RCA p/n# 241275...
The Eeprom is located at U13102 on the signal board..
Bill
Dec 16, 2007 | RCA P52937 52" Rear Projection Television
My Mpio FG100 is messed up! Help! Please!
lol thats not how .... switch the hold switch on, press and hold func botton press play while holding then turn on the mpio while holding after that a screen saying"preceed to format? press rec hold for N secs til screen pops up saying that its doing a low level format
Mar 31, 2006 | Mpio FG100 MP3 Player
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
