Question about HP LaserJet 1300 Printer
Frequent paper jams.
I had the HP LaserJet 1300 printer repaired recently, but because I was unaware of the actual cause of the paper jams, the problem recurred. I believe the cause is not properly setting the printer to print with 24 lbs paper in a 20 lbs. setting. I now need to change whatever part needs to be replaced. I would try to do the repair myself with the help of a repair manual in an attempt to be cost-efficient.
  • 530 Answers
Hi im josh in cebu phils. may i help you? friend if the problem still occurs even though it was already repaired. there is a hardware problem involve possible the paper feeder roller.try to remove it and clean it first so that you can economized the cost.but if it still occur you need to change that already so that you can use the printer. good luck friend.
Posted on Feb 27, 2009
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Apr 03, 2010 | HP LaserJet 1300 Printer
We have a problem in my HP Laserjet 1300 printer, in monitor always that my printer is out of paper but thers a papers in the printer
The is a paper sensor ( black plastic ) at the end of the paper tray against the wall of the printer. Laft hand side of the middle. It may be jammed or stuck. Check to see that it moves bachwards and forwards freely.
Jul 29, 2009 | HP LaserJet 1300 Printer
After 80 % the paper inserted, the second paper will follow inserting to the tray, and next those paper stopping (jam)
Keep you equipmento in a dry place, sometimes the paper absorve humidity, and can cause paper jam due to heat of tonne.
or
Clean your rollers that pull paper inside printer.
Best Regards.
Jun 24, 2009 | HP LaserJet 1300 Printer
LaserJet 1300 jams the paper
Hi there
Use standard paper.
try to shake and bend the papers quote before placed in tray.
thanks
Hamedo
Nov 15, 2008 | HP LaserJet 1300 Printer
H P LazerJet 1300 Problem
you most likely need the current drivers for that HP..try this link, through the HP icon doorway
Mar 20, 2008 | HP LaserJet 1300 Printer
My paper keeps jamming how do i solve it?
you need a new paper pickup feed roller- about $5.00 and easy to replace. This is generally the one part that wears out on these printers. see this article.
http://www.printertechs.com/tech/mkinst/mk-1300-3puroller.php
Dec 02, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
131 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
