IT CANT BOOST TO WINDOW
I CLICK ALL THE BOX IN CONFIGURATION UTILITY SECTION .SUCH AS SAFE MODE ,BOGUE AND OTHERS
  • 530 Answers
Hi im josh in cebu phils.may i helped you friend? if it happens when appear safe mode it means that your pc was not shut down properly in such it causes some software corruption problem. if it doesn't boost even though you have already running safe mode.thats the time you need to re install you operating system such Xp. just try also to repair the software by running again the cd and choose repair. good luck friend hope i helped you.
Posted on Feb 27, 2009
How to get off safe mode
Step 1
Getting out of Safe Mode may be both easy and complicated at the same time. The primary consideration is the reason why the machine is booting into this status. If it was user initiated, the easiest way is to click on the 'Start' button and select the 'Turn Off Computer' option.
Step 2
This will bring up the window with the 'Standby', 'Turn Off', and 'Restart' options. Choose either 'Restart' or 'Turn Off'. Upon rebooting or powering up of the machine, the Operating System should automatically load into Normal Mode. Take note that some users are misled into believing that the system is in Safe Mode primarily due to the incorrect setting of the video. If the system is in Safe Mode, it should be stated at the corners of the screen.
Step 3
If the system keeps on rebooting on Safe Mode, this is a possible indication of a problem in loading startup components. Reboot the machine.
Step 4
During the reboot process, press the 'F8' key to display the boot-up options. In this window, select the 'Last Known Good Configuration' option. The Operating System will attempt to locate the last settings that successfully loaded the Operating System.
Step 5
If still unsuccessful, allow the machine to boot into Safe Mode. Click on the 'Start' button and choose the 'Control Panel' option.
Step 6
Click on the 'Performance and Maintenance' category and click on the 'System' icon. This should open the System Properties window.
Step 7
Click on the 'Hardware' tab and click on the 'Device Manager' button. Check for any exclamation or question mark beside any entry. Reload the corresponding device driver for the erroneous component. Repeat Step 2; this should boot the system in Normal Mode.
Step 8
If the computer system entered Safe Mode via the System Configuration utility, then it can only boot in Normal Mode using the same tool. Click on the 'Start' button and choose 'All Programs'. Click on the 'System Tools' category and select the 'System Information' option.
Step 9
From the new window, click on the 'Tools' Menu and select 'System Configuration Utility'. Under the 'General' tab, select the 'Normal Startup' option.
Step 10
Click on the 'OK' button and restart the machine as described in Step 2. This will load the system in Normal Mode.
Aug 11, 2014 | Dell Inspiron 570 Mt Desktop Computer
Geting PC out of safe mode
Read ther alterations that I have included to take you out of SM
  1. Close any running programs and open Windows so you are back at the desktop.
  2. Click on the Start (vista_start_button.jpg) button.
  3. In the Start Menu Search Box (vista-search-box.jpg) typemsconfig and press enter on your keyboard.
  4. The System Configuration utility will open and you will see a screen similar to the one below.
    Figure 8. Vista System Configuration Utility
    Click on the Boot tab.
  5. You will now be at the Boot options screen as shown below.
    Figure 9. Vista Boot tab in the System Configuration utility
    UNCHECK the checkbox labeled Safe boot
  6. Press the Apply button and then press the OK button.
  7. You will now be presented with a prompt stating that you need to reboot the computer to apply the change.
    Figure 10. Restart Prompt
    Click on the Restart button to reboot your computer.
Jun 16, 2013 | Computers & Internet
HP I let the HP asst. Install a bios update and the install is stuck at 40%. What can I do to get out of the update? HP Probook 4530s
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
Sep 29, 2012 | Computers & Internet
hope this helps
I cant' get out of safe mode. I press f8 and tell it to start windows normally but it goes to safe mode automatically
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 11, 2010 | ASUS 90-A4C1K1000 Keyboard
How do I get my IBM computer windows 2000 out of safe mode??
Hi,this should help.Don't forget to rate.... Getting out of Safe Mode may be both easy and complicated at the same time. The primary consideration is the reason why the machine is booting into this status. If it was user initiated, the easiest way is to click on the 'Start' button and select the 'Turn Off Computer' option. This will bring up the window with the 'Standby', 'Turn Off', and 'Restart' options. Choose either 'Restart' or 'Turn Off'. Upon rebooting or powering up of the machine, the Operating System should automatically load into Normal Mode. Take note that some users are misled into believing that the system is in Safe Mode primarily due to the incorrect setting of the video. If the system is in Safe Mode, it should be stated at the 4 corners of the screen. If the system keeps on rebooting in Safe Mode, this is a possible indication of a problem in loading startup components. Reboot the machine. During the reboot process, press the 'F8' key to display the boot-up options. In this window, select the 'Last Known Good Configuration' option. The Operating System will attempt to locate the last settings that successfully loaded the Operating System. This feature was introduced under the Microsoft Windows 2000 Operating System platform and retained in newer Microsoft environments. If still unsuccessful, allow the machine to boot into Safe Mode. Click on the 'Start' button and choose the 'Control Panel' option. Click on the 'Performance and Maintenance' category and click on the 'System' icon. This should open the System Properties window. Click on the 'Hardware' tab and click on the 'Device Manager' button. Check for any exclamation or question mark beside any entry. Reload the corresponding device driver for the erroneous component. Repeat Step 2; this should boot the system in Normal Mode. If the computer system entered Safe Mode via the System Configuration utility, then it can only boot in Normal Mode using the same tool. Click on the 'Start' button and choose 'All Programs'. Click on the 'System Tools' category and select the 'System Information' option. From the new window, click on the 'Tools' Menu and select 'System Configuration Utility'. Under the 'General' tab, select the 'Normal Startup' option. Click on the 'OK' button and restart the machine as described in Step 2. This will load the system in Normal Mode.This is all that can be done hope this helped.
Nov 17, 2010 | Computers & Internet
Cant get my cumpter out of safe mode.
Dear Sir,
According to your problem it seems to be your PC set to safe boot mode in System configuration.
so follow these steps.
Click on Start>>then click on Run>type msconfig>System configuration Utility opens with several tab like general,system ini,win ini,boot ini>click on boot.ini>there is boot options safe boot,bootlog etc,& notice that safe boot box had check mark,if it is yes remove the check mark click apply then ok. then restart the system.
(These steps for both vista and XP)
After restart Your system in normal mode.
i think it solves your problem,
if you have any query regarding this issue leave a feedback,we will glad to assist you
Have a Nice Day!
good luck
Sep 12, 2009 | Dell Dimension 2400 PC Desktop
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
My laptop is not working right, it is extremely slow and something called Vongo keeps trying to install but won't and it won't do anything
Uninstall Vongo:
1. Restart the Notebook and keep Tapping F8.
2. Select Safe Mode and press Enter
3. Click on Start, select Run, type "msconfig" press Enter.
4. Click on Startup tab and uncheck the check box besides "isuspm"
5. Click OK and restart the system for the new settings to take effect.
Kate: Note: After you restart the machine you may receive a dialogue box stating 'System is running using Selective Startup', Check 'Don't show this message or launch the system configuration utility when Windows Starts' and click OK.
Kate: Now, restart the Notebook again and go into Safe Mode by tapping F8. Click on Start -> Control Panel -> Add Remove Programs.
Locate the Vongo Software and click on Remove to uninstall it.
If this does not resolve the issue, you may have to manually delete the files:
1. Double click on My Computer
2. Double click on C Drive
3. Double click on Program Files
4. Select the Vongo Software folder and press Delete.
5. Close the Window
6. Right click on Recycle Bin folder and select Empty Recycle Bin
This will remove the Software.
Now, run the Windows Installation Cleanup Utility, this will remove the registry entries for the Software.
You can download the Utility from the given below link: http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
(Note: Do not click on the link. Copy and paste the complete link in the address bar of the Internet Explorer.)
The Windows Installer CleanUp Utility does:
• Provide a dialog box where you can select one or more programs that were installed by Windows Installer. You select the programs on the Installed Products list in the Windows Installer CleanUp dialog box. After you make this selection, the utility removes only the Windows Installer configuration information that is related to those programs.
• Remove the files and registry settings that make up the Windows Installer configuration information for programs that you select.
Hope this resolves the problem with Vongo. Would appreciate if you rate it.
Thanks,
ArnWuLF
Nov 30, 2008 | HP Computers & Internet
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
