Question about MSI K8MM-V Motherboard
I have ms 7142 TO INCREASE RAM
THERE IS DDR2 SOCKET IS PRESENT OR NOT
can i use DDR2 RAM IN IT
TO INCREASE RAM
  • 530 Answers
Hi im josh in cebu phils.may i help you? friend sad to say there is no way you can use DDR2 because your motherboard MSI K8MM-V doesn't support DDR2 it is DDR and SDR RAM. so you better use DDR having higher freq.to upgrade your pc. thats all good luck.hope i helped you.
Posted on Feb 27, 2009
What type of RAM is compatible for my desktop pc for increasing speed ?
Your motherboard can support up to 8 Gb of ram, of type DDR2 667 MHz or 800 MHz. In practice 667 would do I believe as the performance difference is not great in practice. The board has 2 DIMM sockets for this.
It depends somewhat on your OS and what you want to do. I'd try 4 Gb first. Bear in mind that added ram doesn't actually speed the computer as such, only a faster CPU does that, but it will allow more windows to be kept open, and cut down on data swapping to virual memory on the hard drive.
Jun 05, 2016 | Intel Computers & Internet
I want to increase the speed of Which type of ram should I use to increase speed of my pc ?
RAM will not increase the speed of your computer. The processor on the motherboard provides a given speed, such a 3 GHz or whatever. It is possible, however, that you need more RAM if you run too many programs or are playing games that need lots of RAM. Go to your manufacturer's website and look up the specs - it should tell you how much total RAM your motherboard will support as well as which type. Go to control panel, then to system. How much ram you have will be listed there. Once you have this information, you can decide if you want to buy more. I have found it is usually best to get RAM all at the same time, from the same place.
Ms-7142 ver:1 audio driver i want a free download Ms-7142 ver:1 ni996 pleade give me audio driver
Hi there
This board is also known as K8MM-V.
If you go here:
Support For K8MM
Then you will find four tabs toward the bottom of the page, the second of which says Drivers. Clicking on this will give you a box further down which is a drop down menu to select your Operating System. Once you have done this there will be a list of all the drivers for this board and you can download whichever ones you want. You should note that this is quite an old board and it does not appear to support any OS above Vista 64bit as there are no drivers for Windows 7 or higher. Also with only 2Gb RAM maximum supported (according to the manual) I doubt its capability to run Win 7 or higher.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 10, 2014 | Computers & Internet
I am lost my drivers so i can't formate my computer
Hello the drivers can be downloaded here:
http://www.msi.com/product/mb/K8MM-V.html#/?div=Driver&os=All
Please select your windows system, click on zip file for download.
Unzip the file when downloaded, before you install the driver.
Not all windows system is supported, such as windows 7.
Other drivers can be downloaded here:
http://www.viaarena.com/drivers.aspx
By selecting your windows system.
Best of luck
Aug 28, 2012 | MSI Ms-7142 K8mm-v Motherboard Via K8m800...
My PC'S motherboard model is MS7267.I m using 1GB Ram at present I want to increase it to 2GB Ram .Will it support it? My e-mail is-imran111bd@yahoo.com. looking forward for ur reply. with regards imran
Hi Imran
Yes .
It supports up to 2 GB but has to be Dual Channel DDR2 533/667 MHz and up(*DDR2 Memory Modules are not the same as DDR Memory Module)
Take this information with you when you buy it or email the website help desk with it if your buying on line.
Hope this helped
Alistair
Jan 11, 2011 | Computers & Internet
Can i use AMD 64bit 3800+ in MS-7142 Ver 1.0 motherboard.
AMD 64bit 3800+ is Socket 939 and MS-7142 Ver 1.0 motherboard is socket 754
Nov 11, 2010 | AMD Athlon 64 X2 5200+, 2.6 GHz
I am going to upgrade ram to 1 gb. can i use ddr2 1 gb ram to upgrade .motherboard is microstar model ms-6526 ver: 2 . present ram is ddr1 400 MHz, 512 MB
If your computer has two RAM slots on the motherboard, i would recommend trying it. The computer will run on the 512MB stick alone and just not recognise the other stick. And if it works it works.
I have searced for support documentation and came up with none for the original MS-6526
I run my original version MS-6526 on a 512MB PC2300 (DDR1) and a 512MB PC3200 (DDR1) and it runs just fine for games and videos.
Personally I would recommend trying the DDR2 first and if that fails, return the card and get a DDR1 card. They are expensive, but at least they work.
Oct 08, 2010 | Intel Microstar MS-6526 Pentium 4 ATX...
Need of motherboard driver ms-7142
Your board is actaully listed as a model K8mm-V on the MSI website. Here is a link to the MSI page with the correct drivers for your board. These will work for Version 1 or 2 boards:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Hope this helps...
Sep 19, 2009 | MSI K8MM-V Motherboard
MS 7142 TO INCREASE RAM
hiya
its a case of purchasing the new ram modules taking the old ram out and popping the new ram in
i wud recommend using OCZ, GEIL or Crucial memory modules as these are the best makes
the spped of the ram varies from system to system depending on the system bus speed
the most common speeds for this board is pc2100, pc2700 and pc3200
these speeds are as follows pc2100 - ddr200
pc2700 - ddr333 and pc3200 - ddr400
hope this helps
Rik
Feb 27, 2009 | MSI K8MM-V Motherboard
I've tried to find your driver but without results.. :/
better try some professional tool like this one: Driver Update Software for XP Vista 7 8
used it many times, and it's awesome.
wish you best of luck
Brian
Aug 04, 2008 | MSI K8MM-V Motherboard
MSI K8MM-V Motherboard Logo
97 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
