Question about HP PSC 1210 All-In-One InkJet Printer
Usb cable connector on printer
I have a hp 1210 all-in-one printer that has a broken pin on the back where the usb cable connects. do you know if this connector is replacable?
    Sergeant:
  • 199 Answers
Yes but there are expert technician required for soldering
Posted on Feb 27, 2009
My printer HP psc 1210 sys it is
When the system is unable to recognize the printer "offline" appears on printer icon. 1. Ensure that printer should be on condition.
2. Check printer USB cable both ends are properly connected or not, remove & re-fix .3. Insert in another USB port. 4. Replace with another USB cable.5. Replace Formatter assembly.(only professionals can do this activity)
Nov 29, 2011 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 printer driver is not installed sucessfully in window 7 64 bit
When you connected the product to the computer with a USB cable, the Windows Update installation failed. Solution You can manually install the driver. Make sure you follow the steps in the order given to reset your printer, remove the product, restart your computer, and then manually install the driver. Step one: Turn the printer off and then on
  1. Disconnect the USB cable from the printer.
  2. Turn the printer off and then back on. Clear any blinking lights or error messages.
Step two: Remove the product from Devices and Printers
  1. Click the Windows icon (c01319360.gif ), and then click Devices and Printers .
  2. Right-click the product icon (c01813941.gif ) representing your HP product, and then click Remove device . Follow the on-screen instructions to complete the process. (If the product is not listed, skip to Step three: Restart your computer.)
  3. If multiple icons exist for the product, remove them all.
  1. Restart your computer. You might want to bookmark this page so that you can quickly return to it.
  2. Make sure your computer has a valid Internet connection by opening a web browser and surfing to an Internet site.
Step four: Manually install the driver
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif ), and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Click the Windows Update button and wait for the updates to complete.
  8. In the Install the printer driver window, under Manufacturer click HP , and then search for your driver under Printers . If the driver does not show up under HP, try looking under Hewlett Packard. NOTE: The print drivers are displayed by their series names, which means the last one or two numbers may show as zeroes. For instance, the HP Photosmart 8750 displays as HP Photosmart 8700, and the PSC 1210 displays as the PSC 1200 series.
  9. Once you find the appropriate driver, plug the USB cable back into the printer.
  10. The Installing Device Driver Software window should briefly display in the bottom right corner of the computer screen. Wait for it to disappear.
  11. Click the Cancel button on the Add Printer window.
  12. The newly installed printer now shows in the Devices and Printers window.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
My printer no connection cable and also power cable what is price for two materials??
You will need to search on the internet or go to your local computer parts shop.
You will need a USB printer cable (approx $10) and a AC power adapter for the HP PSC1210. This will cost about $20-35 depending on which style you chose.
check http://www.sparepartswarehouse.com/HP,PSC,1210,Printer,Power-Supply.aspx
Nov 12, 2009 | HP PSC 1210 All-In-One InkJet Printer
The hp director scan function no longer works properly. How can I correct the problem? Can I load just the hp director from the printer software?Printer is an hppsc 1210 all-in-one.
If this issue occurs, after installing the new version or revison of internet explorer then try to download the "Critical update to resolve an issue with HP Director after installing a new revision of Internet Explorer" from HP Website if the operating system is Windows XP.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=90764
If this issue occurs, in general follow the below instructions to solve the issue.
  1. Download the HP Officejet J6480 All-in-One Printer
  2. Install the HP Officejet J6480 All-in-One Printer while installing do not connect USB cable at any point of time if it asks, check USB connect later
  3. Download the HP PSC 1210 All-in-One Printer
  4. Install the HP PSC 1210 All-in-One Printer connect the USB cable when it asks to connect
Download the printer full feature software based upon your operating system.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3635378&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90764&lc=en&cc=us&dlc=en&lang=en&cc=us
This should resolve the issue.
Sep 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Computer won't recongnize printer
The problem is with the device driver. Every piece of hardware has a corresponding software program called a device driver to let Vista/XP know it is there and what it does and how to do it. If a disc came with your printer then that is what loads the device driver. However, with USB devices you must load the driver with the USB cable unplugged from the printer. Then once the driver loads then plug in the printer...nobody knows exactly why but that is with all USB devices. So unplug and load the disc, then plug and see if it works. You may have to reboot..if that does not work let me know as they are a couple of ways to get it to working. Good luck and keep me updated. Pls rate this solution.
Apr 05, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp 1210 printer
Disconnect USB cable & turn Printer OFF.
Then Clear all pending documents in the printer queqe.
Control panel printer & faxes>> Printers.
Double click printer icon & start deleting all document fron this queqe.
Then restart pc. After restart delete the printer icon completely.
Later connect usb cable & turn on printer wait for few minutes till printer configures & start printing.
Jul 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
USb Printer Cable connection
Your stuck with USB. You can get another USB card to plug into your computer at a computer store.
Jun 22, 2008 | HP PSC 2410 All-In-One InkJet Printer
Hp 1210xi usb socket broken
that's on either mother board or system control board..requires a special soldering device..is it under warranty?
Jun 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
