Question about Intel D845GVSR Motherboard
I turn on my compaq desk top and it wants a file or command
I dont no what to typ in . I cant go no further no display
  • 530 Answers
Hi im josh in cebu phils.may i help you? friend if nothing appears on screen then the main problem is your hardware particularly the video card. first thing to do is you need to check the video card if it is seated properly on the slot. 2nd the connection between the cpu and the monitor check wether the chord is mounted properly. if it still appears remove the extra devices such cd rom sound cards etc.just run with video and hdd only. if it stills occur.you need to replace the mainboard to solve the problem. thats all hope i helped you try to do those good luck
Posted on Feb 27, 2009
My compaq e500 doesn't start. how can i reformat my compaq?
you cant format a computer if it does not start !
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
Sep 21, 2012 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
Compaq laptop
Unplug power adapter from laptop and remove main battery, press and hold power for 2 minutes, when finished install battery and power supply. Now turn on the computer.
May 03, 2012 | Averatec Computers & Internet
My monitor display a box that box display 1028*768 and 85hz due to that i cant see my monitor fully what i have to do?
right click on the desk top and select properties from the settings tab lower the screen size.Go to the advance tab and make sure the dpi rate is set to normal which is 96.
Good luck
Oct 31, 2009 | Compaq 17" Flat Screen CRT Monitor
OMPAQ 700 ous desk top pc will not connect to
in command window try
ipconfig /release
then
ipconfig /renew
to pull a new ip
then try
ping www.google.com
to check if you can resolve hostnames
also try
ipconfig /flushdns
to clear old dns entries.
can also try disabling unused internet adapters, in case there's a conflict
Oct 07, 2009 | Compaq Presario 4410US (470027-053) PC...
The monitor works fine up to the log on screen. It will show the desk top for a few seconds, then it goes to a yellow light.
try logging in safe mode and remove display driver and then start in normal mode....do reply if this works
Oct 03, 2009 | Computers & Internet
My MS Office files can not Open
i am not famalire with this
so try this
goto start bottom left hand corner go into search box
and typ the name of one of your filels slow you should see it come up
dobble click on it try if u need to drag it to a new box on windows desk top
Sep 16, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
My display wallpaper change to solid colour suddenly after 5 minute i change it
hi there,
well,anytime you can change your display wallpaper you can restore it on windows screen left click ,then click properties,click desk top select what display you wanna put on to your windows,you can also put your picture of your family,your love ones,on desk top click browse select my picture,then click the pictue then click ok,its all yours have a nice day don't forget to rate me
Apr 06, 2009 | HP Compaq Presario SR1303wm PC Desktop
DESK TOP
recent u changed any hardware and software configuration
other wise u will change memory
Jul 17, 2008 | Computers & Internet
Desk top
Open a run command and type in:
regedit.exe click [OK] and locate this Key:
[-]HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\System = Look in the right pane/window for "No wallpaper" and remove it.
Right click on the Desktop then select Properties. On the Display properties:
1- click on Desktop tab
2-Click on Customize Desktop Button
3- Click on Web Tab and make sure no check box is checked there, uncheck if
there is a check box.
Reboot your machine and see if you can change the wallapaper
Mar 24, 2008 | Compaq Armada M700 Notebook
Intel D845GVSR Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
