Question about Citizen 8700 BL8000-54L Wrist Watch
Basic my strap is to big and i want to take a couple links out how do i do it?
  • 2,334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 27, 2009
How to remove stainless steel wrist band on a marc
You should find a couple of pins buried away at the watch side of the strap. These are spring loaded and hold the strap in place using tension.
Simply put the watch face down on something soft, the clips should be visible at the corners of the strap and take some needle nose pliers or small flat screwdriver and push inward from one of the outer edges. This will squash the spring and enable you to remove the strap.
Oct 15, 2014 | Watches
Casio 3053 strap - I need to remove 1 or 2 links from the strap. How do I do this ? Thanks.
take a pish pin, inside had a arrow , that is the big head out , cotter pin. tap on pi opposit hole. pin comes out and pull . when inserting in pin tap down pin until it is in band.
Jun 17, 2011 | Casio A168W Wrist Watch
Its too big to fit my hand good but also i cannot shorten it enouph so it can fit me without being extremely tight. Is there an alternate way to shorten it. I noticed 4 holes where the clasp is and was...
Some clasps have holes in them to allow you to adjust the straps in smaller steps than removing links.
It sounds as though yours in one of these.
The pins are spring loaded just like the ones used to fasten the strap to the lugs of the watch, so you can apply a probe to one end of the pin with one hand, while applying a gentle force in the direction you wish the strap to go with the other hand.
Then do the same with the other side and repeat as needed.
Jan 05, 2011 | Breitling Bentley 6.75 A4436212.G573.970A...
Watch strap a little big
mcdevito75 here, Maybe a link or 2 can be reoved from the metal band, or an adjustment at the clasp can be done. Look for a small watch repair shop in your area, they can help.
Jul 08, 2010 | Casio A168W Wrist Watch
How to make the strap shorter
Those are very difficult to adjust. Unless you adjust those often, then your best bet is to take it to a watch repair business and let them adjust it for you! :-)
Jan 07, 2010 | Citizen Watches
How to adjust a Rubber strap
well all i did was cut the strap
Aug 30, 2009 | Watches
Gossip watches with changeable ribbon straps
good day,
hope this link below will solve your problem.
watches
Jun 24, 2009 | gossip Rectangle Case Leather Strap Watch
I can't find strap for Nike wr0021-002
Agence from Belgrade helped me find a strap,thanx.
Feb 18, 2008 | Nike WR0021-002 Wrist Watch
Removing links
It?s very tough to remove the links, I would recommend taking it to a dealer If you have to, you will either need a fine punch (or very masonry nail), a medium hammer, and a piece of wood a couple of inches square, a rag or wash cloth. A sturdy flat blade watch makers screwdriver. The ones from a dollar store may not work, and a pair of pliers. There are two types of links, both of them are a pig to remove, expect lost fingers, lots of swearing and possible scratched strap. Version one, The one I think you have, Place the watch strap flat on something hard, put a cloth under it so it will not mark, the outside of the strap will be on the cloth and you will see the arrow, there is a rectangle with a nipple recessed inside. Place the blade of the screwdriver between the nipple and the edge of the rectangle, press down and wiggle between the nipple and the edge and twist, there will be a locking pin which comes out of the side link, in the direction of the arrow. Wiggle away until you can free the locking pin. It?s simpler to put them back. Version two, Place the rag folded a couple of times on the block of wood Place the strap on the rag so it?s on it?s side, hang the watch over the edge of the block so the strap is flat against the block and there is nothing touching the watch (hanging in air) Look at the edge of the strap, see the small pin, in the fold of the metal, punch it out (down into the cloth) enough to then grab it with the pliers, I actually drilled a small hole in the block of wood so the pin would be pushed into that rather than against the wood, but don?t drill holes in your dining table! I would still recommend taking it to a dealer,
Apr 05, 2007 | Fossil BQ9183 Wrist Watch
Citizen 8700 BL8000-54L Wrist Watch Logo
226 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
