Question about Itech iOP4000WT Television
Sagem axium hd-l32 stuck on standby
Please help red standby light on,when i switch on the power switch i can hear the tv and fan start up but will not come on regards shaun
Sagem axium hd-l32t/1 Display Problem??!!
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 05, 2014 | Televison & Video
Service mode tv lcd sagem axium l32
To know more about this, check the site linked here. It has details about entering, adjusting and exiting service mode to many popular TVs. Pull up older posts.
Nov 27, 2013 | Sagem HD-L26-TP 26 in. HD-Ready LCD TV
No power at all
Check the capacitors in the power supply, check for any bulged tops. Your problem is most likely power supply related.
May 21, 2012 | Televison & Video
Sagem Axium HD D45F TV Bulb needs replacing - any ideas of a local repair in the Stoke on Trent Area
http://www.ascolti.co.uk/blogs/robsblog/files/sagemaxiumbulbreplacement.html
or
http://robertleather.wordpress.com/2007/09/09/replacing-the-bulb-on-a-sagem-axium-hd45-hs-dlp-television/
Nov 16, 2009 | Televison & Video
Sagem Axium HD-D45 S G4.T/2 of (HDD-D45F) range.from standby lights go red/ orange flashing, then the fan should start up and t.v picture appears. The fan does not start up and no t,v picture and the set...
Sagem Axium HD-D45 S G4.T/2 of (HDD-D45F) range.from standby lights go red/ orange flashing, then the fan should start up and t.v picture appears. The fan does not start up and no t,v picture and the set reverts back to standby
Aug 04, 2009 | Sagem Televison & Video
Tv help
This is bad. You need to either be under warranty on these big screen TVs or get the service manual. Especially since this is an off brand.
Jan 01, 2008 | Televison & Video
Banding on LCD TV
you need a new motherboard
Dec 09, 2007 | Televison & Video
Itech iOP4000WT Television Logo
391 people viewed this question
Top Itech Televison & Video Experts
Electro Med Services...
Are you an Itech Televison and Video Expert? Answer questions, earn points and help others
