Question about Sony Walkman NWZ-S616F MP3 Player
Icon how do i create an icon on my tool bar to open up my media windows player..it only opens when i put a cd in
  • 62 Answers
Go to my computer then C:/ and then click on program files the Windows media player find the icon to open it and right click then select create shortcut
Posted on Feb 27, 2009
I bought some old radio shows on from amazon, and it such a large number of shows that they put them on a dvd . I would like to down- load them on cd so I can play them in my car or cd players....
It depends on the format that they were put on the DVD initially, to play these on a car stereo or CD player they may need converting to be recognised by a standard CD player.
In vista, you can use Windows Media Player to do this. I'd recommend copying them to your computer from the DVD by creating a folder called "radio shows" or similar in an area you can easily find again On the desktop is a good place.
Now open Windows Media Player and insert a blank CD into your CD/DVD drive (I'm assuming you have an optical drive that will burn cd's)
In the menu of Media player, you will see a tab called "burn", click on it and you get the option on the right of the pane to "create a burn list". Make sure the icon says audio cd
Now open the folder you just created called "radio shows", select the first shows you want to burn to cd and drag the file onto the area marked "drag items here to create a burn list"
As you add files the CD meter should start to fill up, when it is near full, you can click on "start burn" which is at the bottom of the pane. Your compilation should now burn to a cd, repeat for the next cd.
If you get stuck, under the burn tab, there is a help with burning guide
Jul 24, 2011 | Computers & Internet
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
How to put program type on tool bar
  1. Adding Icons to the Task Bar
    1. Click on the Start Menu to open it
    2. Click on "Programs" and find the program for which you want to create an icon
    3. Move your mouse pointer to the program you want to use
    4. Depress and hold down the right mouse button while you drag the icon to the Quick Launch toolbar section of the Task Bar
    5. When you release the right mouse button, a short menu will appear
    6. Choose "Create Shortcut(s) Here." An icon will be created in the Quick Launch toolbar on the Taskbar
  2. Deleting Icons from the Task Bar
    1. Move the mouse pointer to the icon you want to delete
    2. Right-click on the icon
    3. Choose "Delete" from the short menu that appears. The icon has been deleted, but the program is still available to you on your hard disk
    NOTE: If you have carefully followed the steps above to add the icon to your Quick Launch toolbar, deleting it will NOT delete the program from your computer, it will simply remove the icon from your toolbar. The program will still be available to you.
Also you can "Drag" the program, to the bar, and "Drop" it on it. Check out a freeware application called StartupCPL at http://www.mlin.net/StartupCPL.shtml. This places a Startup icon in your Control Panel which, when opened, lists all applications on your PC with a check box for each one. Simply put a check mark in each application you want to open minimized on startup. By the way, it states it is for Windows ME and 2000, but I have had it on XP for quite a while and it works fine.
Mar 01, 2010 | HP Pavilion dv6000z Notebook
I have put a cd onto my computer as a folder how
You will have to convert the audio CD to mp3 before you can load it on your phone. Open Windows Media Player, go to tools (right click on the top bar if the menu is not available), and click options. Under the RIP tab, change the format to MP3 and select the quality you want (suggest middle of slider bar). Click OK and insert your CD. Now click on the RIP tab at the top of Media Player and rip the tracks you want to your computer. After you do this, you can then copy the newly created MP3 files to your phone.
Jan 29, 2010 | Dell Inspiron 530 Desktop Computer
Can't download music from computer
What happens when you chose open to see files, this is how I us mine. I go to the folder tree and drag my files from the computer folder to the music folder on the player. If you use windows media player you can convert cd's to mp3 from the menu at the top. if you can not see the menu right click the top bar next to the now playing button, and chose classic menus. Then go to -> tools -> options -> rip music tab and look for the folder it will put mp3's in or change it to a folde you make at the top of the folder tree say ( create a folder named AAA. right click the top c:\ drive and create a new folder and re-name it aaa that will put it at the top). then in the rip music location chose mp3 rip when cd in inserted and close out and your good to go. rip a cd and drag it onto your player.
Jan 25, 2010 | Audio Players & Recorders
I lost the software cd for my sony nw-e507
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 27, 2009 | Sony NW-E507 MP3 Player
I have installed windows XP and MM 2.1.4026.0 version. Whenever I create and save a movie it is saved with a windows media player icon and when i replay it the following message is displayed. "windows...
Hello, instead of saving it as a MovieMaker file, save it as an .avi or a .wmv file. That way, Media player can locate the right codec for this file.
Aug 21, 2009 | Computers & Internet
Disney mix max problem
Connect your player to the USB port on your computer using the USB connector on the Mix Max. A 'MIX-MAX' window will appear in your My Computer folder which is the player's internal memory. To add more files and songs to your player simply drag and drop MP3 or WMA files from anywhere on your computer into the 'MIX-MAX' window.
For Windows XP, you can utilize Windows Media Player 10 software to convert music on an audio CD into MP3 or WMA format as follows:
Open the Windows Media Player 10 Browser, then click on the 'Rip' icon on the top tool bar. Insert a Music CD into the CD-ROM drive of your computer.
Click on the 'Tools' menu option at the top menu bar, then click on 'Options'; the Option setting menu will appear. Click on Rip Music and set the Rip music to the desired location on the newly ripped music (MP3 format or Windows Media Audio format). Adjust the audio quality as desired. When finished, click 'OK' to confirm the settings.
Click on the 'Rip Music' icon to start ripping the music to your computer.
When the music tracks are ripped; connect the player to your computer. Open the 'MIX-MAX' window and open the ripped music location window.
To add the transferred/ripped music file/songs to your player simply drag and drop the MP3 and/or WMA files into the 'MIX-MAX' window.
When the files are finished loading into the player, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to convert music on an audio CD into MP3 or WMA format.
Downloading WMA files with DRM using Windows Media Player 10 (for Windows XP)
To download WMA files with DRM, follow the procedure described below using the previously installed Windows Media Player 10. Before beginning the procedure please turn the unit on and connect the unit to the computer as previously described.
Open the 'Windows Media Player Browser 10' and click on 'Sync'.
Click on the 'Sync List' pull-down menu to locate the music files you wish to download. Then make sure to click the box next to the files.
Select the Portable Device that you want to copy to from the right side drop-down menu. Click 'Start Sync' to start downloading the WMA file(s) with DRM to the Portable Device.
After finished downloading all the desired files to your unit, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to download WMA files with DRM to your player.
Jun 16, 2008 | Disney Mix Max Digital Media Player
Albums disappeared
you could try using windows media player to create playlists and store music files, it's so much easier to use too.
Jan 16, 2008 | Samsung YP-K5 MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
