Cars & Trucks Logo
Anonymous Posted on Feb 27, 2009
Engine swap: 440 into a '97 ram sport 2wd
I started a drag project with my truck which is a '97 ram 1500 sport 2wd short-box. right now its my daily driver, but i am looking for help with the installation of the engine and trans. the engine is a '69 440 block w/a 512 cu. in. stroker kit and aluminum heads from 440 source.com the drive train is a 727 w/3500 stall and 9.25 transaxle w/4.56 gear. my question is where can i find the proper motor mounts? i have the 5.9 L 360 stock in it now, but i need help with motor mounts/any hardware needed to stuff my big block in the engine bay and have all measurements lined up. any help would be appreciated
  • Anonymous Feb 28, 2009
    thank you for answering my question, with the 440 engine mounts, are they standard size/design for all chrysler vehicles for all production years? i bought the 440 w/o the mounts and im just wondering if i go to my auto parts store, or order on line, will all i have to ask for is engine mounts '69 440? maybe i will just go to summitracing, or racing junk.com thank you!
Dennis Mulford
Level 3:
Genius:
  • Master 1,055 Answers
  • Posted on Feb 27, 2009
Dennis Mulford
Master
Level 3:
Genius:
Answers
1055
Questions
8
Helped
379060
Points
3163
Use the 440 mounts change the frame mounts too 440 frame mounts
  • Dennis Mulford
    Dennis Mulford Feb 28, 2009
    they may have changed the desgin from year too reay so get the year your block is
2answers
I put 2014 rims on my 2010. Tire pressure issues. screen on the dash is showing psi's blank. how do I reset? I assume these 2014 rims would have stock sensors in them, and there basically brand new.
Some Chrysler ,Jeep and Dodge vehicles have ttye pressure sensors calibrated to the vevicle,so therefore if you change the
tyres to a different type you will need to take your vehicle to a C.J.D.
service department to have the computer of your car re-programmed to accept the new tyres
2001 dodge ram 5.2 motor swapped out of a 1996 dodge ram turns but don't start
Is it possible that you did not swap the ECM module along with the engine
1helpful
Engine code p1297 on 2001 dodge ram 1500 with 3.9
P1297 DODGE Description The Engine Control Module (ECM) detected no change in MAP sensor voltage.
- MAP Sensor harness is open or shorted
- MAP Sensor circuit poor electrical connection
- Faulty MAP Sensor
- Faulty ECM
I had a trailer on my 2008 dodge ram and there was a short and now the lights on my trailer don't work if it's not a fuse with is it? Is there a relay?
You should check the engine compartment fuse box. If not there is a number of steps you can take to diagnose wiring issues. I wrote an article awhile back illustrating these steps. Please click here to view.
5helpful
01 dodge ram 1500 5.2 4WD code P0455 evap system leak.
This code will not stall or no start of your engine, evap only work when engine is off, it is to reduce the fume your gas tank lets out to protect the o zone, but it will not pass Emission test, also could be some thing a small as your gas cap not sealing right.
9helpful
I need routing guide for serpentine belt for 2002 Dodge Ram 1500 Sport Quad cab 4.7 L v-8, Diagram on truck is damaged.
HI. I have located a good diagram. Kindly follow to assist with the proper routing. Use caution when installing your belt. This is the routing for your engine specs.
4helpful
Sprak plug Wires Need To Be Installed Correctly
You have several RAM sub-models in here:
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} B1500 RAM Van
B2500 RAM Van
B3500 RAM Van
RAM 1500 1/2 ton 2WD
RAM 1500 1/2 ton 4WD
RAM 2500 3/4 ton 2WD
RAM 2500 3/4 ton 4WD
RAM 3500 1 ton 2WD
RAM 3500 1 ton 4WD
Chrysler Full-Size Trucks 1989-1996 Repair Guide
To avoid confusion, remove and tag the wires one at a time for replacement.
Fig. 1: 2.5L 4-cylinder Engine. Engine Firing Order: 1-3-4-2. Distributor Rotation: Clockwise
Fig. 2: 3.9L V6 Engine. Engine Firing Order: 1-6-5-4-3-2. Distributor Rotation: Clockwise
Fig. 3: 5.2L and 5.9L V8 Engines. Engine Firing Order: 1-8-4-3-6-5-7-2. Distributor Rotation: Clockwise
Fig. 4: 8.0L V10 Engine. Engine Firing Order: 1-10-9-4-3-6-5-8-7-2. Distributorless Ignition
Hope helped with this (remember rated this help) Good luck.
2answers
Pls help my signal lights on my 1500 dodge ram van not workin
u probably jus hav to buy new ones ... if u dont know how to put them in then right me back and il tell u .
Help
It may be a bad starter or the starter solenoid. If by not starting you mean it will not turn engine, but if the engine is turning then the starter is turning so it is something else all together.
Starters will usually work when they are cold then once warm or hot they will not work.
Hope this helps!
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
