Question about Hotpoint Ultima WF860 Front Load Washer
Is the hotpoint aquarius a cold fill only.
My boiler is broken but i would like to use my machine without it.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
If ther3e are 2 hoses they will both need a water supply but you can get a 'y' connector from diy stores and attach both hoses to one cold supply.
the water is heated by the machine anyway.
Posted on Feb 28, 2009
Where is filter on my hotpoint aquarius wmf540 washing machine, im getting white fluff over all my clothes everytime i put a wash on, im guessing the filter needs cleaning and just wondered where it is
http://laundry.manualsonline.com/manuals/mfg/hotpoint/wma58_wma56_wma54_wma52_wma50_wmm59_wmm53.html?idRes=599752
see last page.
also, you should try run a cycle without any clothes (add a bit of bleach) in it in cold water for once to rinse out the dirt.
Oct 02, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius will not heat water
Although I do not know your particular machine I strongly suspect that the heater element is malfunctioning/broken. Even if it is a hot and cold fill it still requires the element to heat the water up to the correct temperature for the selected wash. If it is cold fill only it certainly needs the element all of the time- apart from rinses!
Sorry but it depends now on who you have at hand to repair as to your next step.
John C
Feb 09, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
Does the hotpoint aquarius require hot and cold supply to washing machine
Depends on the model, and when it was manufactured.
If there is only 1 inlet valve connection at rear of washer, then it is cold fill only.
If there are 2 inlet connections, then it is hot and cold fill, this applys to washers only, and not washer dryers
Feb 28, 2010 | Washing Machines
Hotpoint Aquarius WDD440 washer and dryer
Possibly Pump blocked. or impeller broken. without taking a proper look but sounds the obvious.
Jul 26, 2009 | Hotpoint Aquarius WD63 Front Load...
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
My service washing machine keeps filling up with water even on spin cycle
Your Fill valve Solenoid has failed.
Some machines have an all-in-one type fill valve
(hot and cold on the same valve - but different solenoids)
some have seperate bodies for the hot and cold.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius wd640 my boiler has broke so could you tell me if my washer drier is a hot or cold water fill
Most washers made today, are cold fill only, best way to check is look at rear of washer, and if there is only one hose, then it is cold fill only, if 2 hoses, then hot and cold fill..
So if your boiler is not working, then it should be o/k to use if cold fill only.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
