Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Hey, I got a ryobi RLT30ces string timmer over xmas, Iv used it a couple of times without any problems but now I cant get it started. When I used it I had the fuel mixed with oil. Iv had a look over a few things and I have spark, compression and the primer bulb fills when pressed, the only thing that I can see wrong is when I prime it no fuel seems to be getting into the bore for the spark plug to fire, it stays dry. Id say that the carby has a blockage after the primer bulb for this to happen, just wondering if any one else has encounted this problem?
  • wayne_dennis Mar 02, 2009
    Hey Mr jerr, thanks for your help but unforunatly cleaning out the carby didnt help. I pulled it apart as much as I could but it seems to be blocked in the jet at the butterfly which cannot be removed to clean. any other ideas?
3 Suggested Answers
SOURCE: Ryobi RLT30CES
I have one of these and I have to admit they are a bit of a bug*er to start. Following the instructions though on the sheet for trying to start it eventually should kick it off and then you should be away. I start mine by alternating between no choke and the half choke with about half a dozen pulls each. generally pull with the throttle held but try a few with it off every now and again. If you get to 10 mins without success, put it down, have a drink and a rest and go back in 30 mins and try again.
I wouldnt have thought a straight petrol mix would do it any harm though, if you had over mixed with oil then that could have been a differnt story.
Posted on Jun 02, 2008
demonsm
  • 253 Answers
SOURCE: i have a problem with my ryobi rlt30ces its seems to be sum kind of fuel blockage it ticks over then dies checked spark plug ok cleaned out carb im mystified
Put a new primer button on it the old primer diagram is old and has gotten tough less flexible and will stick and cause a kind of back pressure that will not allow the fuel to flow. Had this kind of problem on my stilh.
Posted on Aug 08, 2012
My pull string wont move on my ryobi x430
Mine seized up and the string wouldn't pull because my girlfriend used it a few times without making sure that the oil was full. I filled the oil well with Marvel Mystery Oil and was able to slowly get the string to move. Eventually the motor became lubricated enough to pull the string with regularity and now the weedeater works perfectly.
Apr 06, 2012 | Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
I replaced start string and have no recoil of it on a Ryobi 30 cc
Watch the video, about 60 seconds in he explains how to tesion it.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 01, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Nov 30, 2009 | Ryobi Garden
Ryobi RLT 30 CES Strimmer - Won't run properl7
I'm not sure about the carb. adjustment being removed. The newer carbs. only have one dial for adjustment, not the two screws like the "old school kind".It probably needs the carb. cleaned. Disassemble the carb. and clean with carb. cleaner. Use a Den Tek Brush, (used for cleaning teeth), to clean the small portals. Make sure the small screen in carb. is free of debis. The smallest of particals can cause your problem. Reassemble and try starting. If it still acts up, buy a carb. kit for trimmer and replace the needle valve, appropriate gaskets, diaphragm, and small screen. This should solve the problem.
Jim
May 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES line trimmer head problem
Many small line trimmers lack a clutch system by design so this could be normal.
May 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi RLT30CES
I also tried this.
  1. Clean the carb wire gauze air filter behind the roto-choke knob. (undo the nut/washers & long bolt)
  2. Deteremine if fuel is being fed to cylinder - Fully depress & prime the bulb about 7 times, turn to full choke. Pull start cord about 7 times. Remove spark plug see/smell fuel fumes/vapour present in cylinder
  3. Determine if compression is weak - remove plug, put finger over plug port, pull start cord. Should be evident of resistance/pressure build up when cord is pulled.
  4. Of course brand new plug!!! as above (I would try this first)
Hope this helps
please rate my comments - Thanks
Aky1967
Jun 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES
May 25, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
356 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
