Question about Sharp AR-235 Copier
Sharp AR-287 fault code E7-11
Tried turning machine on and off, fault will evetually clear after several hours, (turning machine back on after auto power off).
Any help greatly appreciated.
  • parkerfab Mar 02, 2009
    Thanks for the reply, though it's obviously not the easy-fix answer I'd have liked, it's appreciated.
    Regards
    President:
  • Sharp Master
  • 990 Answers
Hello sir; The error code means there have communication problem between main board and sub board,operation board, icu board or print, my suggestion, go buy a new copier, it not worthy to repair !
Posted on Feb 27, 2009
My AR-5320 Sharp Copier is Blinking h-4 please send me the code to repair it.
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
Sep 14, 2011 | Sharp AR-5320 Black and White Copier
Sharp 157e H4 blinking,where is the fuse and or thermostat to check. This Church copier is 6 years old and paying a technician several hundred dollars to come out to fix it is crazy. Do you have any...
Aug 09, 2011 | Sharp AR-157E Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H-4 is an error code for the fixing assemblyand needs to be reset thru a simulation code, sometimes a power flucuation can cause this error and therefore may not need parts.
press #
press *
press clear
press *
when it is done properly the display will go blank
then enter 14
then press the start key, turn the machie off and then back on.
If the code comes back you'll need something for the fixing assembly
Good luck
Bob
Apr 27, 2009 | Sharp Office Equipment & Supplies
Need to clear the key operator code
Have you tried 00000 ? Five 0's is the default key operator code. Press the Custom Settings key then on the display press the Key Operator Programs then 00000 when prompted.
Mar 25, 2009 | Sharp Office Equipment & Supplies
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Mar 17, 2008 | Sharp AL-1641CS Laser Digital Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-235 Copier Logo
483 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
