Question about 3Com 10BaseT RJ-45 Network Interface Card Network Adapter
How to crimp rj-45 cable - 3Com 10BaseT RJ-45 Network Interface Card Network Adapter
  • 2,386 Answers
Rj 45 price?
Just buy premade cables at monoprice.com, they cost a few dollars a piece.
Sep 01, 2011 | QVS 100pcs CAT6 RJ45 50u Crimp Connectors...
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
How di I terminate the QVS Cat6 RJ 45 plugs?
terminating a RJ 45 plug means to put a RJ 45 plug on the end of a suitable cable. This is done by making up a si\uitable cable and skinning the tips of the cable and inserting them in the right order to the plug and then using a special RJ 45 crimper mashing a plastic plug down on the wires. You can purchase such an arrangement from an electronics supplier.
Jan 06, 2011 | QVS 100pcs CAT6 RJ45 50u Crimp Connectors...
How we join it with computer which LAN wire is use state or cross and proceser to joine
Your question is a little confusing ... chain saw networks?
I believe you want to know how to build a wired computer network ...
You will need special tools to do this including a RJ-45 crimp tool. You should use the highest quality ethernet, 'Cat 5', Cat 5e', wire available to you. On the ends you will install RJ-45 connectors (8 conductor 'plugs'. Choose and stick with one of the several color codes for placing the conductors into the RJ-45. Color code guide should come with your special tool. Make sure the ends are in proper order, trimed square and inserted fully into the connector before you crimp. Purchase a test tool to verify your work. Expect to pay $50.00 US or more for the testing tool. Cable, connectors, wire, router or switch and other hardware should be available where communications or electrial supplies are sold.
Thank you for your interest in FixYa.com
Aug 10, 2010 | Garden
I have a cable modem that doesn't want to accept the RJ-45 cable (I think that's what it is called.) I've tried several different quality cables with no luck. Strange problem. Any tips?
Some RJ 45 jack cable has fault so try with another RJ 45 jack cable .. Purchase new rj 45 jack cable from nearest computer shop. There must be 2 port on modem 1 for ADSL phone line cable and otthr for LAN ethernet port means RJ 45 jack port. Try with another rj 45 jack cable it should be connect.Make sure that LAN port of modem is not faulty means make sure pins on that port are not break. Let me know if you need further assistance. Thanks for using FixYa.
Jul 24, 2010 | Computers & Internet
How to attach cat 6 cable to rj-45 jack
Good day..You should have knowledge about the color coding for cat-6 cable termination. Its called "termination" computer term.if it is a straight-throw use this color code:RJ45 must face at you when you arrange the wire colors..WOrange,Orange,WGreen,Blue,WBlue,Green, WBrown,Brown..(W=White). Then use a Crimping Tool to crimp it.Flat that twisted wires before you insert to rj45. Hope you are okey with this. Ask me if problems occured. Mastergani
Mar 17, 2010 | Computers & Internet
ADSL Modem Huawei SmartAX MT841 USB driver not supporting Window Vista Name update of Vista
Hi!
Do not use the usb port or cable. use the RJ 45 port instead. and configure PPPoE and connect using UTP / STP cable with RJ 45 connector straight crimped.
Jul 27, 2008 | Computers & Internet
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a cat5e network cable i am hooking to rj45 flush mounted wall jack the wire color is not the same?
Either your wallmount is not correctly crimmped according to the standards or your cable is not correctly crimmped according to the standards. So its better you crimp the cable and fix the R.J 45 connector in the sequence given herewith.colour coding of the cable:-
1-oranage white
2-orange
3-White green
4-Blue
5- White blue
6-Green
7-White brown
8-Brown
The same Sequence should be at the wallmount and at the R.J 45 connector.
Apr 26, 2008 | Computers & Internet
Cat5e
Some testers do not test ALL the wires. Some will only test pair 1 and 2. You may want to use a DVM (Digital Voltmeter) set on the ohms function and check continuity on each of the eight wires from RJ-45 to RJ-45 connector or use a cable tester that will check all the wires. If you use a DVM check 1 to 1, 2 to 2 etc. for continuity. Good will read 0 ohms, open will read infinity or OL on some meters. 90% of all cable problems are poorly crimped or broken wires at the RJ-45 connector. It is difficult to be sure which end has the bad connection so you may need to change BOTH RJ-45 connectors. Do one, then check the cable, if it doesn't work, do the other one. It is a 50-50 shot. I prefer and encourage the rewiring color code using the EIA 568A standard. Starting at pin 1 the color code would be orange-white, orange, green-white, blue, blue-white, green, brown-white, brown. You don't have to do it that way, but you must make sure that the same color wire is on the same pin on each connector. If all else fails, you can go to you neighborhood computer shop for help in installing connectors. It takes a lot of practice to do it right. Hope this helps
Nov 30, 2005 | Honeywell Multimedia, Cat5e X2, RG6/U...
Computers & Internet Logo
395 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
