Question about ALi Do It Best Precut Drywall Sandpaper [Misc.]
Hole in my wall
I need to repair a hole in my apartment wall before I move out and have never done that before.
  • khalicoe Mar 03, 2009
    The drywall around a small wall-mounted bathroom heater has broken edges. How do you repair a broken edge, it's not a hole, just ragged edges that show around the metal heater faceplate.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
If the hole is less than an inch diameter: use a hammer to tap the hole edge to bevel around the entire hole. Using the screen type drywall seam tape, cut the tape slightly smaller than the beveled area. Apply drywall spackle or compound to the hole, flush with the surrounding surface, then gently press in the tape evenly. Let it dry (6-8 hours), then lightly sand or wipe over with a damp sponge. Now apply a final coat of compound flush to the wall surface. Touch up with paint.
If large, say 6" or more: get a friend that does drywall to do the repair unless you have woodworking experience! Short of that respond to this FixYa and I can walk you through it.
Posted on Feb 28, 2009
I have a panasonic viera plasma tv model number TC-P60U50, where on tv do I put brackets to mount to the wall?
You will need to purchase a suitable wall mount separately. (You'll need one for LARGE TVs.) On the back of your TV set you'll see there are 4 holes in the lower-central region of the rear panel. They are about 20" apart (left-right) and about 12" apart (up-down) These should match up with the bracket that comes with your wall mount. You will need M8 metric screws that are about 1.25" long. These will also be included with the wall mount. (Which will include some general directions for wall mounting.)
Here is a manual for your TV:
PANASONIC Viera TC P60U50 Owner Manual Page 7
Feb 09, 2016 | Panasonic Televison & Video
Tip
Minor Drywall Repairs
<span>It takes about 4 days for a good patch to be made. You can buy the materials in small quantities at the hardware store, so it won't cost much at all for a small hole, and a little more for a larger one.<br /><br />For a hole smaller than a tennis ball, you can press newspaper crumpled loosely into a ball into the hole, as much as you need, to build the hole up to just below the surface, then cover with overlapping layers of drywall mesh tape. The directions for a larger hole follow, and you can skip the first parts of it if you do not need them (if you are using the newspaper method.). With this method (newspaper) the most important part is to remember that the first coat of spackling is just to anchor the tape and bridge the repair, no more.<br /><br />The easiest way to repair a larger hole in wall board:<br />1. Cut a piece of new wall board larger than the hole you want to repair.<br />2. Take your wallboard "patch and hold it over the hole. Draw the outline of the patch on the wall.<br />3. Using a drywall saw, cut out the outline of the patch on the wall.<br />4. Cut a piece of wood longer than the hole is tall, by about 4". Measure back from each end 2".<br />5. Start a drywall screw 1" above the patch outline, centered. Align the wood in the hole with the lines you made on it at 2" back from the ends. Screw the drywall screw into the wood. Do the same at the bottom. You'll want the drywall screw to be below the surface while trying not to break the paper surface of the drywall.<br />5. Fit your patching piece into the cavity, and, depending on how large the hole is screw through the patch and into the wood with one or two drywall screws.<br />5. Using self-adhesive drywall tape, tape the crack around the patch, overlapping at the corners.<br />6. Use pre-mixed drywall spackling with a 4" putty knife to apply the first coat of drywall spackling to the patch. The aim here is to secure the new drywall to the old, so you need to use the putty knife to press the spackling into the crack, and lightly coat the drywall tape. If your screws that were used to secure your wood to the back of the old drywall are outside of the tape, press the spackling into the screw dimples as well. If you hear a "ticking" sound as you pass over the screws with the spackling, the screw isn't set deep enough. Give it another turn or so, until you don't hear it tick when you pass over it with the knife. Let all of this dry for 24 hours. Clean your tools, and dry them.<br />7. The next day, sand any burrs that stick out, but sand lightly, trying to taper the patch out onto the old wall. Don't be too particular, as there is still a ways to go. Using the drywall knife and spackling, re-coat the patch, blending more onto the wall, and leaving a little more material in the mesh of the drywall tape. The cracks should be refilled, as they'll have shrunken in overnight, so this is all done at the same time. Don't over-work it, just give it a good coating, and leave it alone. The screws that you previously spackled will get another coating at this time as well. You're done for the day, clean and dry your tools.<br />8. The next day, lightly sand the burrs, again feathering a bit onto the wall. Try to remove the dust from sanding with a dry cloth, lightly brushing the patch and wall. This should be the final coat today. Lightly apply your spackling, feathering it out onto the wall. The aim here is to make the finished repair invisible to the eye, so feather out onto the wall at least the width of your blade, if possible. You can fill the screw holes again as needed, feathering the spackling out from the screw dimples onto the patch and wall. Done for the day. Clean and dry your tools.<br />9. Day 4. Sand the patch, feathering out from the patch and across the patch. It should appear relatively flat to the eye, with the cracks and screw holes filled and feathered. No tape should be sticking out. It will all appear smooth. It is ready for matching paint.<br />Hope that this was helpful.<br />Best regards, --W/D--</span>
on Feb 03, 2011 | Plumbing
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
Wall-e u comand robot, will not move forward he just turns, can i fix the right wheel?
On the in side of the body (cube) is a white gear the size of a 50cent coin. It is pressed on a drive shaft. The inter ring is cracked and slipping. It makes Wall E turn around and around. I'm looking for a replacement or some one with a makerbot to reproduce it. If any one finds one let me know at. stevepiper@usa.com
Apr 19, 2012 | Disney Wall-E U-Command Remote Control...
Fixture for curtainrail wentthroughplasterboardbig hole now help.me fix please
Hi, W/D here.
Feb 03, 2011 | Washing Machines
How does the YB2808 holder detach from the wall? ......the above answer wasn't an answer....I need to know how to "unsnap" the thing....it IS NOT held on with typical allen screw, how does one...
The anchor is put into the wall in a pilot hole, a mounting post is inserted into the wall anchor, Afterwards the mounting post is pressed firmly until it clicks to stay in the mounting post with the handle down. The locking tab on the mounting post is faced down to fit into the specific area to stay put.
  • If this was over tightened it will be difficult to get off.
  • Try moving the handle from side to side, while pulling the unit off.
  • If all else fails, put tape around the handle, then slide a flat head screw driver under neath, and lift up. the anchor bolt will now want to come out but it can be cut off. Push it back in. Repair the hole and try again if you are moving it anyway.
Dec 10, 2010 | Moen YB2808 Eva Paper Holder - Chrome
Replacing heating element in oven-connecting wires fell back in
hey sorry about that,as a repair man i hold on to those babies like crazy.almost all ovens i worked on [its many]the rear wall dose not come apart.if yours dose great go that way.but other wise yes you have to go thru the back.i would try fishing abit more before i pulled it out if was me.God bless,tom
Jan 02, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Little tikes log cabin wall and door cracked in move
If the wall holding water is your concern, drill a large hole in the bottom of the wall where it meets the ground . Then, water will not collect in there.
If you are concerned with pinching little fingers then use a small amount of silicone caulk on the cracked areas and let it dry in the sun for about 12 -24 hours.
Let me know if you need anything else!
Oct 08, 2008 | Little Tikes Picnic On The Patio Playhouse
ALi Do It Best Precut Drywall Sandpaper [Misc.] Logo
221 people viewed this question
Top ALi Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an ALi Measuring Tool and Sensor Expert? Answer questions, earn points and help others
