Question about Macromedia Computers & Internet
If we have lote of virus in oure sistem ,
We cont find [fscomman("exec","some_btn")] from the sorce of batch file
  • 54 Answers
Better get a good antivirus or you will be in bad situation (No Trials they don't work)
Kaspersky good choice
Posted on Feb 28, 2009
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
Kinds of computer virus and their definition
There are few types of viruses. There are trojan, who control your computer. There are batch files with unwanted commands (it activates only if you open it). There are programmed viruses who are not controled, but have they'r own path or list of commands (sort of "to do" list).
Jul 19, 2010 | Computer Associates Anti Virus 2008...
Can not Find. Script File C:\WINDOWS\System32\CleanViirus.vbs
it is a virus plz follow the instruction bellow to remove this virus:
  1. Go to Task Manager –> Processes and End the following processes in order:
    1. dxdlg.exe
    2. wscript.exe
  2. Go to Start –> Run –> regedit –> Open the following key:
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon
  3. In the right hand pane, select Userinit and delete everything except “C:windowssystem32userinit.exe”
  5. Make sure the processes wscript.exe and dxdlg.exe are not running.
  6. Delete the following files
    1. C:WindowsSystem32dxdlg.exe
    2. C:WindowsSystem32boot.vbs
    3. In your Windows drive, search for boot.vbs and delete all of them.
    4. In your Windows drive, search for kinza.exe and delete all of them.
  7. Disable System Restore and then Enable it again.
  8. Restart your computer.
Hopefully everything will be cleaner now and your computer will be free from boot.vbs virus icon_smile.gif . Please share your experiences.
Mar 31, 2010 | Microsoft Windows XP Professional With...
How to write script in 2003 domaincontroller
Hi
please follow steps to resolve your issue
First, open "Active Directory Users and Computers" on the domain controller
Now right click on the user you want to have the logon script and select the properties menu.
A properties dialog like the one shown below will appear. Select the ‘Profile’ Tab
Here is the confusing part. If I just put any old batch file name in the logon script field, where does windows try to find it from?
Lets find out. First, type in this field ‘logon.bat’
Click OK.
Now, we need to find the folder where the server loads logon scripts. It follows this format:
\\(SERVERNAME)\sysvol\(DOMAIN NAME)\scripts
So, if my server was named DCServer1, and my domain was intelliadmin.com, we would browse to this path:
\\DCServer1\sysvol\intelliadmin.com\scripts
Now that we know where to put it, creating the script is easy. Just open up notepad, and write your batch file. For our test batch file we will put in a line that loads our profile generator for Microsoft Outlook XP
We are done with the script, so we save the text file as:
\\DCServer1\sysvol\intelliadmin.com\scripts\logon.bat
Now, the next time this user logs in, they will load the login script.
Check out our Windows Admin Tools
Filed Under: Windows
hope it can resolved your issue
thanks for using fixya
Mar 25, 2010 | Computers & Internet
Operanting sistem in quarenten
Any antivirus; unless it finds virus, never moves a file to quarantine. If it moved, then probably your OS is occupied entirely by virus.
Which antivirus are you using? Are you able to login into your system ? If yes, open the quarantine folder and replace all items. It is best if you do it in safe mode. Then scan for that trojan horse again. But before that, back up your important data and then scan. I recommend you remove all the virus after backing up of data and format your system once (all drives) and do a fresh install of OS.
If you are unable to open quarantine, try system restore to restore to a point earlier before that scan. It is in All Programs>Accessories>System Tools.
Jan 16, 2009 | Microsoft Windows XP Professional
When scanning to "batch to file" or "scan job" in captureperfect
Check if thee is virus in your system. Some 'autoplay' viruses do this.
S. Mohan
Jan 15, 2009 | Canon DR-9080C Path-Through Scanner
Problem with my cowon a2
Why don't you try to scan your cowon, with your antivirus??? it should work... and so you'll be able to get rid of the troyan.
I started scaning my A2 a while ago (I have kaspersky ) and it worked.
Jun 09, 2008 | Cowon System iAUDIO A2 (30 GB) Digital...
How to compress file in Veritas exec 10
Make sure that your tape drive is using Symantec drivers. to do this follow these steps.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 31, 2007 | Veritas Backup Exec 10 for Windows Servers...
Lunix scripting
Assuming you have ALLCORES directory: su - root find /tmp -type f -name core -exec mv {} ~/ALLCORES \;
Sep 22, 2007 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Tony
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
