Question about Sentry Fireproof Safe
When i put my last digital number in the red light comes on and error blinks i have a safe with the key and then you put 5 digits in and turn the lever then it opens the sentry safe A5 406618
  • David Shaub May 11, 2010
    Be more specific. Do you have a safe with a key or a combination? And, what are you asking?
    Scholar:
  • Sentry Expert
  • 170 Answers
When the red light blinks that means you are entering the wrong code. If your batteries went dead the safe delets the user code Check your owners manual for the default factory code number. Programing instructions.
Posted on Aug 06, 2010
  • 80 Answers
Http://www.sentrysafe.com
see link above.
mj
Posted on Sep 07, 2009
How do I fix my Sony TV?
Sir
please one thing remember that red led blinking indicate specie fault please watch red light count and find the correct fault which is written below
Monitoring Items Number of Flashes of red led Main Power Supply Voltage Error 2
DC_ALERT1 3
DC_ALERT2 4
DC_ALERT3 5
Backlight Error 6
Internal Temperature Error 7
Audio Error 8
Digital FE Error 10
Trident Error 11
Balancer Error 13
T-CON Error 14
thanks
Sep 22, 2017 | Sony Televison & Video
I need the tv code number to put into my Jensen Universal remote control for a Panasonic TV on cable, TV Model# CT-27S18S. I also need to know how to program these numbers into the Jensen remote Remote...
the panasonic numbers are one of the following
0051, 0250, 0055and to program it you need to do
Turn on the component that you want to set up.
Press and release the component key you would like to configure. The red LED will blink once.
Press and hold the "Setup" key until the red LED blinks twice, then release.
Enter the first 4-digit code number for the device you are trying to program. The LED will blink one on each digit entered, except for the last digit where it will blink twice to confirm that a valid code has been programmed.
Now test the code by pressing the "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 3 and use the next 4-digit code listed.
Mar 16, 2011 | Panasonic (TH-50PZ700U) Television
How to program radioshack 3 in one remote to a panasonic dvd home theater sound system sa-dm3?
hi,
try any one of the following code. if not work do the following steps to find out code.021, 107, 035, 081, 110, 162,225, 454,035, 162,051, 054, 055, 250
MANUAL CODE SEARCH
If the 3-in-One Easy Remote Control does not op-erate your remote-controlled devices when you
first set it up, you might have to manually find the correct code for your devices. you can
follow these steps to search the remote control's entire library.
1. Manually turn on the device you want to set
up.
2. Press the corresponding device key (TV,
VCR, or CBL).
3. Hold down P until the red light blinks twice,
then press 9, 9, and 1. The red light blinks
twice again.
4. Aim the remote control at the device you
want to operate.
5. Repeatedly press PWR then the device key
for the device until it responds to the command.
6. When the device responds to the command,
press P within 5 seconds to save the code.
Note: If you do not press P within 5 seconds,
the remote control does not save the code.
• Because the remote control's library has
so many codes, this procedure can take
several minutes.
• If your device turns off during the search,
but does not operate after you lock in the
code, begin the search again, pausing
longer between key presses.
Determining the 3-Digit Code
After you set up your remote control using manual code search, you can find which 3-digit code the
remote control is set to by following these steps.
1. Press the device key you want to get the
manufacturer's code from, then hold down P
until the red light blinks twice.
2. Press 9 9 0 . The red light blinks twice again.
3. Press 1 then count the number of times the
red light blinks. This is the first digit of the 3-
digit code.
Note: If the red light does not blink, the digit
is a 0.
4. Repeat Step 3 twice to find the second and
third numbers of your 3-digit manufacturer's
code, pressing 2 and 3 respectively for each
additional digit.
ok
Dec 14, 2010 | Panasonic Televison & Video
Lost my instructions to operate the remote control. I have the code list, but i don't know how to imput the right code on the remote. My model is JER321
Configuring codes:
1.Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
2.Release the component key.
3.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
4.Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
5.Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
1.Turn on the component that you want to set up.
2.Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
3.Release the component key.
4.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
5.Press "0" - "9" The green light will blink as codes are sent.
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
Thanx
Jul 30, 2010 | Jensen JER-321 Remote Control
I LOST MY INSTRUCTIONS LIST FOR MY REMOTE CONTROL DEVICE....THE MODEL IS JER321
Configuring codes:
Auto Code Scan:
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. 7.If none of the codes turn your component off, return to step 2 and start over.
Thanx
Jul 30, 2010 | Jensen Televison & Video
Need to know how to program a jenson jer 323 with a Sharp tv
Configuring codes:
Auto Code Scan:
Thanx
Jul 29, 2010 | Jensen JER-323 Remote Control
By turning the key on and off does not pull engine codes in 2001 dodge the system has changed
With the battery connected?
With a Digital Odometer: Turn the Key from Off to On (not start) three (3) times, On the third (3rd) time leave it in the On (not start) position. The Codes will appear in the Digital Odometer Screen. When it is finished it will show "PdonE".
It is on the 2001 Dodge Caravan.
Without a Digital Odometer?
Turn Key the same way and leave the same way.
Watch the Engine Light (yellow) and count and record the blinks. Do it a few times to get the count correct.
These are 2-digit numbers. The last set is 5-blinks and 5-blinks indicating that it is complete.
Jan 01, 2010 | 2001 Dodge Caravan
I have to unplug wait for the power light to stop flashing red multiple times before it will come on
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
RED LIGHT
press and hold the menu and device/input buttons both in together for 5 seconds then the led will blink a number of blinks pause then blink another number of blinks then repeat that process. Let me know thw binks you get for the two digit blink error code.
Feb 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I cannot open my safe.
try holding the # and the * key for 5 seconds that should reset the safe and open it up
Dec 22, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
625 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
