Question about Intel Core T2300, 1.66 GHz Core Duo (BX80539T2300) Boxed
Want to buy a new computer for personel use , which cpu is better dual core or core2duo girish email. girishpratap@yahoo.co.in
  • David Shaub May 11, 2010
    It all depends on what you want to do with it.
    Scholar:
  • 93 Answers
If you going to be using intensive programs like 3d editing, gaming, video editing, photoshop/image editing, or just multitasking and keeping alot of programs open you should get a faster cpu speed, and probably the core 2 duo. Core 2 duo (intel) is dual core and 64bit which gives more processing power, for some applications. Dual core is just normal processor (32bit) and just has 2 cores.
CPU is basically for the computers thinking/multitasking/processing info. If you want to multitask alot of programs your going to need processing power AND alot of RAM, the more the better/faster. If your going to be gaming or doing intesive stuff with graphics, you need a powerful video card. And hard disk is solely dependent on your storage needs too.
If your just going to be surfing the web, emailing, facebook, watching dvd's, and whatnot, any computer (new) should do you fine. But if you want HD video you need a powerful video card and processor.
Also When I mean powerful I dont mean the most powerful, just the mid-range of 'power'. So if you want to get anything more than basic, go for a mid-priced PC. Also this will let your computer last longer as updates and new software tend to slow down your computer, and you need more power to keep up with new stuff, but don't worry, it wont happen that fast!
Posted on Feb 27, 2009
Want faster processor for acer x1300 it base unit
Here are the spec on your pc if the information you gave me is correct. You can only upgrade the cpu to the socket you have. I think you would be better off adding more RAM and a better video card that isn't onboard. Processor / Chipset
  • Type AMD Athlon X2 7450 / 2.4 GHz
  • Number of Cores Dual-Core
  • 64-bit Computing Yes
  • CPU Qty 1.0
  • Max CPU Qty 1.0
  • Chipset Type NVIDIA GeForce 8200
Aug 18, 2013 | Acer Aspire X1300 Dual Core 2.4ghz, 3gb...
What is the main difference between a dual core CPU, and a Core2 Duo CPU ?
A dual core processor has two cores (essentially, two CPUs on one chip). Core2Duo is a specific dual-core processor design. Thus, all Core2Duo CPUs are dual-core CPUs, but not all Intel dual-core CPUs are Core2Duo designs.
Essentially all current Intel consumer dual-core CPUs today are Core2Duo designs. They have different names, but vary mostly in terms of their FSB speed (mostly, how quickly data can be transferred to/from RAM) and in the amount of cache memory in the CPU (cache memory is a relatively small amount of high-speed memory on the CPU chip that stores frequently-used data and instructions; it can improve performance 4-15% or so, depending on the amount).Best Regards, Luis.
Mar 02, 2012 | Computers & Internet
I cann't play fifa 11
you need a graphic card - I have geforce 9600
Feb 24, 2011 | Computers & Internet
E001 ERROR WHILE OPENING FIFA-11
Fifa 11 Recommended Requirements:
CPU with Dual core processor (Core duo 2 or better). Intel Core2Duo @ 2.4Ghz on Windows XP / Windows Vista / Windows 7.
1 Gigabyte of RAM (2 GB required for Windows Vista / Windows 7).
DirectX® 9.0c
Compatible 3D accelerated 256 MB video card or equivalent (**must support Shader Model 3.0 or above). ATI RADEON HD 3870. NVIDIA GEFORCE 8800 GT
If your system does not support the above hardware requirements you cannot play this high graphics games & your get the E001 error.
Feb 03, 2011 | Computers & Internet
Can i change my processor? AMD LE-1150 to dualcore or core2duo?
If your using AMD LE-1150 you cant use a dualcore nor a core2duo because the socket of your motherboard is for AMD microprocessor only you can upgrade or change your procs to any AMD AM2 dual core model make sure you check the specs of your motherboard for supported CPU list. you can find that in their website
Apr 27, 2010 | AMD Sempron LE-1150 2.0GHz Processor -...
I have a pentium 4 cpu on asus p5gpl can i change the cpu into duo cure for example does the motherboadr support higher cpu?
I have had a look at the Asus website and i doesn't appear to support dual core or core2duo.
Sorry. If it is about 5 years old, then if you can afford it , buy yourself a newer upto date MB, CPU and Memory.
Sorry I can't help any further.
Jan 19, 2010 | ASUS P5GPL Motherboard
THIS MOTHERBOARD SUPPORT PROCESSORS WITH 2 CORS ?
http://www.asrock.com/mb/cpu.asp?Model=K8NF4G-SATA2
looks llike you can put an amd Sempron-64bit cpu in.
Oct 13, 2009 | Asrock K8NF4G-SATA2 Motherboard
Pc Chips P23G wont reconize my new p4 core 2 duo
The PC Chips P23G versions 1.0A & 3.0 will not support any current generation Core2Duo, Core2Quad or Pentium Dual-Core processors. Only some of the first generation (Conroe Core) Core2Duo processors which run @ 1066mhz bus and some Pentium D (presler core) processors which run @ 800mhz bus.are supported. Not even most current BIOS will add support for any current processors. Check the pcchips website for CPU compatibility for the P23G..
Mar 22, 2009 | PC Chips P23G Motherboard
E8400 or Q6600
personally i have the q6600 which is a quad core processor, all the others you listed were dual core, personally i use alot of programs all at once which is good if you have a quad core, but just for general music, data, and streaming, the e8400 is probably better for you, its a 3ghz processor.
Mar 20, 2009 | Intel Core 2 Duo E8400 LGA775 3.00GHz 6MB...
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Jun 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel Core T2300, 1.66 GHz Core Duo (BX80539T2300) Boxed Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
