Question about Chatterbox HJC-FRS Stereo Communicator (2 mi. Range) 2-Way Radio
HJC-90 Specs? Hello, I have a Chatterbox HJC-90 that I bought secondhand. I'm trying to determine a few things. 1) I have some walkie-talkies that have the following frequencies. Should they be compatible? 1-7 FRS/GMRS 8-14 FRS 15-22 GMRS 2) All I can get it to pick up is static - any idea why? Even this is itermittent and seems to have to do with exactly how I hold it. Is it an antenna problem or something?
I have an hjc-90 and need an extension cable for the headset. What is the part # and where can I get it?
Posted on Jun 11, 2009
My walkie talkie motorola em1000 have buzzing sound when another walkie is talking. and have buzzing sound when pressing the button.
Just a few thoughts: It is possible you have a bad (blown) speaker on the buzzing radio or the radio has another problem.
A few things you might try include: 1) Cleaning your battery contacts, 2) trade batteries with the known good unit and see if the problem is solved, if so replace the battery, 3) check the mic and speaker holes on both units to be certain they are free of debris and/or stickers covering the holes. 4) if none of these solve the problem, then your radio likely needs retired/replaced.
Best regards.
Dec 30, 2013 | Motorola Walkie Talkie 2-Way Radio
Motorola T8550R
Not all Motorola FRS radio models use the same designations for a give frequency or tone. You may have trouble talking with models different from your own...
Apr 28, 2013 | Motorola Talkabout® T8500R Two Way Radio
Ok i baought 2 Motorola MJ270R walkie talkies, Then i found 1 more with no charger or anything at my moms house, And there all the exact same walkie talkies there all MJ270R Walkie talkies, And was w
Hello Ty,
Tis a problem you have there, however I would advise you take one of your radios to radioshack or similar store, and the folk there should be able to assist in finding the apropriate chargers for you.
I hope this helps you in your quest.
Cheers,
Peter
Mar 08, 2013 | Motorola Walkie Talkie 2-Way Radio
I bought walkie talkies with 56 km radius and yet we are lucky to reach each other after approx. 1 mile,any idea why we don't get the range
You do not mention the particular model of Motorola, so this answer will be generic in nature. Some Motorola TalkAbout radios have been factory programmed with a few GMRS repeater frequencies. These channels require the use of a repeater tower, which will 'repeat' what you say over a greater distance. It is possible you have this type of radio. Check your user guide, and then set your radio to the appropriate channel for the repeater in your area.
Radio-to-radio without the use of a repeater you can expect up to 2 miles line-of-sight out of most handheld radios. This distance is reduced by obstacles such as buildings, trees, etc. inbetween the radios. It can also be reduced if you do not hold the antenna of the radio perpendicular to the ground.
Best regards.
Jan 19, 2012 | Motorola Walkie Talkies 2-Way Radio
Can the gmrsx1 talk to the hjc-frs
Yes, the Chatterbox is a GMRS / FRS Radio transmitter. If both radio transmitters are tuned to the same channel/subchannel, they should have no problems interacting.
Jan 31, 2011 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
Channels
All gmrs radios also have frs frequencies in them. The frequencies are staggered.....1 frs....1 gmrs....1 frs....gmrs etc etc.
The only difference between frs and gmrs is power.... you are allowed to use more power on gmrs freq. So thats why they have more range. But the frequencies are right beside each other.
I would be surprised if your friends radio did not have frs channels in it also.
They should be able to communicate... most likly not on every channel but there should be some that the 2 of you share.
May 09, 2008 | Chatterbox HJC-FRS Stereo Communicator (2...
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
Chatterbox HJC-FRS Stereo Communicator (2 mi. Range) 2-Way Radio Logo
645 people viewed this question
Top Chatterbox Radio Communications Experts
eradiostore
eradiostore
Shaun Baxter
Shaun Baxter
Level 1 Expert
John L radiodude365
Are you a Chatterbox Radio Communication Expert? Answer questions, earn points and help others
