Question about Edirol UA-4FX External Sound System
I cant hook up mic and guitar same time
I figured out how to hook up samson CO1U on track one but when i plug my acoustic guitar into 1/8 jack then the computer switches from the Samson to the guitar. I need to know how to get the mic on one track and guitar on the other so I can sing and play at same time. I have a dell desktop with windows vista Heeeeeeeeeeelp
  • David Shaub May 11, 2010
    How many tracks does your multiplexer have?
    Genius:
  • 1,066 Answers
Get a 1/8" stereo to mono splitter from radio shack or the like. it should have 1 1/8"male end, and two female ends, you could possibly get a 1/8" male with 2 1/4" female connectors, or use an all 1/4 inch adapter, with a 14/ to 1/8 adapter on the male end.
this should divide the guitar and vocals into left and right channels.
Posted on Feb 27, 2009
I bought this microphone w/ sonar LE. The mic is
You can probably solve your problem by plugging your mic into a powered usb hub, then plug the hub into your computer.
Jul 01, 2010 | Samson C01U Consumer Microphone
Samson G-Track mic does not work with garageband effects
Look man just use the input as a way for your pre-amp's to plug in.... you don't want any of those built in guitar effects anyways... You just need a good multi pedal.. There are many good recording Pre-amps out there that work great and are fully adjustable for easy recording.. You can do what you want but, I think you will like the sound of pre-amp effects pedals in your computer set up....
Thats just a tip
Sep 04, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Can't Plug In Guitar
Hi gtrackhelp
Just stick the mic in front of the guitar amp :) That easy really. Even though it is a cheap amp, you will still get results(probably better than you expect.. In the studio thats how all guitars are recorded. If you have any more questions, happy to answer. Cheers
regards
robotek
Oct 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Inputs
ok, heres what try contacting the support line on your samson mic and ask the setup if you are going to connect an acoustic guitar, there might be some info for it. actually there is here check this out
Acoustic Guitar
There are a variety of ways that the G Track can be used to mic an acoustic guitar. The
microphone placement will depend on the type of instrument and what kind of sound
you’re looking to capture, for example the tonal quality you want to focus on, and how
much finger slide or pick noise you may or may not want. When miking a standard
steel string acoustic, a good place to start is with the microphone positioned pointing
towards the end of the fingerboard at a distance of about 6 inches to 2 feet away from
the instrument. You can experiment by moving the microphone slightly in the direction
of the sound hole, which will produce more low frequencies, or move it in the direction
of the fingerboard to capture more high-end or to remove any unwanted boominess.
For nylon string acoustic, try positioning the microphone above the bridge to emphasize
more of the attack from the sound of the finger picking, or for less, move the mic closer
to the sound hole. If you have a pair of G Tracks, try one positioned at the fingerboard
and the second over the sound hole.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson
try using the instrument input lets see if its going to change something.
SAMSON CO1U USB MIC FAILURE
Your first issue is vista... it just sucks. I would have to be there to figure this one out but im going to state the obvious, does it have an installation cd you didnt use? does it have online drivers you can find? Try looking around in your control panel and messing around with some of the options, good luck.
May 01, 2008 | Computers & Internet
Edirol UA-4FX External Sound System Logo
114 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
