Question about Dell Latitude D505 Notebook
DELL Latitude D505
Just out of warranty wont fire up,no lights of any kind no sounds no screen..have removed battery and just used chager still nothing
  • 1 more comment
  • Redd Foxx Mar 16, 2009
    bought a new power cord and it still wont power up
  • davidm13 May 11, 2010
    Try "clearing the static" remove all power sources from the laptop, and hold down the power button for about 10 seconds. If this does not work, issue may be in the motherboard.
  • Barry Parks May 11, 2010
    Does the led on the transformer light up when connected to an AC source?
  • 30 Answers
Have you tried the other fix? It often times works.
Remove the battery AND the power cord.
Hold the power button for 10 seconds.
Now plug in the power cord.
Magic should happen
Posted on May 01, 2009
When i run my dell latitude d505 on the battery the screen dimms
click on the battery and go to more power options and there you can change the time on the screen to dims or just disable it to do nothing
Apr 27, 2014 | Dell Latitude D505 Notebook
The screen on my Dell Latitude D505 became grainy and exhibited pink and green areas. Normal colors were gone. And then, the screen went black, however when I shine a flashlight on the screen, I can...
hello
very much sounds like the back light in your screen has gone. this is a small flourecent light that is fitted inside the bottom edge of the lcd screen, these can be replaced , best bet is try another screen. if screen ribbon cable is ok, realy only a few other things it could be, inverter, or graphics card. i hope this helps you
Aug 09, 2013 | Dell Latitude D505 Notebook
Dell latitude D505 battery not charging
Take Dell latitude D505 battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
Mar 31, 2013 | Dell Latitude D505 Notebook
I got a dell latitde d505 wont power on or anthing no blinking lights no noises. i plug it into the charger n the charger light goes off. can some1 please help me??
Sounds like you may have fried your dell latitude. I have seen many laptop's fry and it is nothing you did, but they just go sometimes.
Recomendaitons:
Take the battery out of the laptop.
Plug the charger in.
Hold the power button for a minimum 10 secs (which will reset the power options)
If there are still no lights than it is your cpu
If the computer turns on then you have a bad battery.
When batteries are bad or dead, the computer tries to run off of the battery befor the charger, it switches over to the charger after your OS has booted. In that case you can just order a new one no big deal, but if your cpu is fried then there is no hope for the laptop. :( I have lost four laptops because of this, so for your sake I hope its the battery or the GND Drain.
Also possible that the GND's drain on your board is too short and Gate 4 is driving low. To fix this you have to remove a SMT ceramic cap, which is located opposite side to the power connector, almost under it. I would guess at 1206 or slightly larger and there is an 0402 cap just next to its bottom pad at 90 degrees to it. A couple of Dell Latitude d505 have had this problem and can easily be fixed, but must be cautious and know what you are doing. I would advise seeing a professional.
Please don't forget to rate :), Thanks!
Oct 07, 2010 | Dell Latitude D505 Notebook
Display is very dark and can barely be viewed. Brightness controls don't do anything. Any suggestions? It is a Dell latitude 505.
Sounds like the back light has gone.
You may be lucky and you just have a loose connection, its worth taking the front off the screen surround and re-seating all conectors.
If it is the backlight, you can get a replacement quite cheap (£10)
I found this site
http://www.keyboard4laptop.com/ccfl-backlight-lamp-dell-latitude-d500-d505-p-4580.html?currency=GBP&language=en
Jul 11, 2010 | Dell Latitude D505 Notebook
My dell 505 has lost the screen, i can faintly see something on it, but not sure what happened
sounds like the bulbs gone, try brightening it up. if no joy you can buy these screens on ebay for a very cheap price just search you make and screen. dell latitude d505 lcd display, should find oen there. hope this helps
Dec 03, 2009 | Dell Latitude D505 Notebook
The sound is off on my D505. How do I get it on
Download the latest drivers for your Dell Latitude D505 off the dell website or try enabling sound in your operating systems control panel.
I said "Operating Systems control panel" because you did not mention what operating system you have.
Oct 27, 2009 | Dell Latitude D505 Notebook
Non powering
hi! the motherboard is dead. if the ac adapter light turns off when plugged in and if you unplug it, it will turn on, then the problem is with the motherboard. It needs to be replaced. Call Dell Tech support if you still have warranty to have the motherboard replaced or else, you have to pay for the repair.
Hope this helps!
Karlox
Dec 16, 2007 | Dell Latitude D400 Notebook
Dell Latitude D505 Notebook Logo
214 people viewed this question
Alun Cox
