Lexmark X125 Pro All-In-One InkJet Printer
Problem for Lexmark X125 Pro All-In-One InkJet Printer
Lexmarkx125 will scan larger pictures but smaller ones.
By sammygirlchi on Feb 27, 2009
My scanner will scan pictures from recently that are larger in size, but when I tried to scan older pictures that are a lot smaller it says to open cover and remove paper jam. Any suggestions on what I can do to fix this problem?
Solution #1
posted on Feb 27, 2009
Not Rated)
SteveLXK
Rank: Wiz  Lexmark StaffLexmark Staff
Rating: 82%, 67 votes
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Was this helpful?
Yes
No
Popular Solutions for Lexmark X125 Pro All-In-One
Questions and Unsolved Problems for Lexmark X125 Pro All-In-One
Do you recommend Lexmark X125 Pro All-In-One InkJet Printer?
Answer
Answer
Calibration print outs are ok but any other application copies have unprinted 1/4 inch blank top to... (More)
Answer
have new hp competor no disc to download can you help me,
Answer
printer worked fine i had to unplug it and when i plugged it back in it says add left cart. the... (More)
Answer
Is the Lexmark X125 compatable with Windows Vista or not?
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Newport, KY
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
