Question about Samsung SGH-i750
READING OF SIM
WAS MY SISTERS PHONE , ALL HER NUMBERS ARE STILL ON THE PHONE MEMORY. WHEN I PUT IN MY SIM IT DOES NOT LOAD MY NUMBERS . WHERE CAN I SELECT WHAT MEMORY IT USES .JUST WANT TO USE MY SIM MEMORY NOT THE PHONES.WOULD REALL APPRECIATE YOUR HELP THANKS
    Problem Solver:
  • 11 Answers
In the menu where you see your numbers just check the option in the menu and try to find out the copy option. i do not have the said phone other wise i could help you straight forward.
Posted on May 04, 2009
How do I delete contacts from sim card
copy the contacts on the sim card to a sd card in the phone. If you don't have one, get one and put it in the phone. Set up the memory in the phone to both sim and memory card. Copy the contacts onto the memory card. Remove the memory card and then go about deleting the contact list in the phone. Put the memory card back in the phone and set the memory in the phone touse the memory card only...not the sim. You're done.
Feb 24, 2015 | Cell Phones
Just got new c5 put in sim card from other phone & can't locate my contact list
The contact list in your other phone is in the PHONE MEMORY. So what could be done is to put back the SIM into the old phone and choose contacts, open and select- MOVE CONTACTS- SELECT FROM PHONE TO SIM and move.
once the SIM is full you can load to the new phone and tranfer using the same method. Then reinsert and follow after erasing the SIM memory.
Aug 03, 2011 | Nokia C5 Cell Phone
I put my sister's memory card into my phone, to transfer music onto her phone. After I took out her memory card, & inserted mine.. My phone was messed up & had no bars.. & it said it was out of...
turn on the handset fully. Take out the battery and leave the battery out for 30 seconds to a minute. along with the sim card. Replace the sim and battery and turn the handset on again. should be fine then
Jan 14, 2011 | Samsung Comeback Cell Phone
Deletion of Contacts from i mate jama 101 without sim
Are the contacts in phone memory or in sim memory?? If in phone memory, There's no problem. Switch on the phone and manully delete all contacts. There's no need of the sim to be inserted. If the contacts are in sim memory then insert the sim. Switch the phone on, and scroll contacts. Chek and find the no.s which have the sim image, it will surely be a sim contact. Then delete it. If you are fearing that your contacts ( if in sim memory ) will be deleted and it is important then first switch on the phone with sim. Note down all sim contacts, after that delete. Then if you give your sister another phone which she likes, switch on the phone and then install all sim contacts which you earlier noted down.
Aug 16, 2009 | i-mate Jama 101 Smartphone
I Put Music On The MicroSD Card But It Won't Show Up On The Phone
Try formatting the card and then put the music back on once the card is formatted. also, see if the phone even recognizes a memory card being inserted. you should be able to press menu>Media tab>other>Memory card... if it doesnt recognize a memory card, the card mght be bad. Does your sisters card work in your phone? if not, it could possibly be a faulty device. if thats the case you can call AT&T warranty center at 1-800-801-1101 for a free replacement
Aug 04, 2009 | LG Xenon GR500 Cell Phone
HELPPP! i just paid my sister 50 dollars for this phone and she forgot the unlock code..now im out fifty bucks.. can someone help me out... i have the imei number
You need two mobile phones. 1) Do _not_ turn off the mobile phone! 2) Remove the Memory Card (MMC) from the locked phone and put it into a second mobile. Install FExplorer on the second mobile phone. Create the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into this directory. 3) Remove the Memory Card and place it into the locked phone. The THC-NOKIA-UNLOCK program should start after 120 seconds. 4) Remove the battery. Remove the MMC. Put the battery back and restart. The Phone Lock has been reset to "12345". Or call your sister and get the unlock code.
Jun 09, 2009 | Nokia N73 Cellular Phone
Phone not reading sim card
dont worry there is some prblm in ur sim pls contact ur customer care there is no prblm in ur phone
Oct 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
LG Shine Bar KE770
Ah ha - the prob above has everything to do with phone memory. Once the full contacts from the sim card are transfered to the phone memory the phone history and sms can read the contact name. However, the phone does not automatically sense when a loaded number does not have the +61 country code attached to it, so every single phone number in the contacts needs to have this added so that incoming sms and calls are correctly identified. An interesting experience.
Apr 24, 2008 | LG Shine KE970 Cellular Phone
My Motorola Razr v3t wont read the memory card
if its out of another make phone then you need to put it in the original phone and format it before it will work in another phone
Mar 25, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Text message identity
you need to put the name and number on your phone memory and put the phone to read from the phone's memory and it will show up....
Nov 21, 2007 | Nokia 2600
Samsung SGH-i750 Logo
66 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
