Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Top Load: I clean the drain after FL code and now the water is not pumping in. What it could be? Jacob.
  • 163 Answers
You may want to take the hoses off the back of machine and check to see if screens are clogged.
Posted on Mar 05, 2009
It wont work it flashes fl
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washer is loaded, the lights are on but after I hit start the machine makes a grinding sound and then displays FL, but does not start the cycle.
The FL error code means:
Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
The problem on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a backup valve or flap in the drain assembly that seems to sometimes cause problems with the FL error code.
The FixYa Team
Dec 27, 2010 | Maytag Neptune MAH6500A Front Load Washer
What does FL mean
The problem on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.The other possibility is door lock latch got faulty and needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
Jul 22, 2010 | Kenmore Washing Machines
Why,wont fl light go off after cleaning screens
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!@#@
May 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I turn on the top load washer ,it starts to fill
Flood Condition:
Oct 13, 2009 | Kenmore Washing Machines
My Kenmore Calypso washer is saaying LE and FL. what does this mean?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@%^
Jun 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune mah550bww will not start up , gives a code FL
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a backup valve or flap in the drain assembly that seems to sometimes cause problems with the FL error code. Remove this piece to see if it helps.
If this is a new installation - check that the hoses arent reversed (cold on hot and hot on cold). This will also cause the FL error.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
When I wash something with a lot of lint my washer stops draining or pumping out. In the past we have been able to pull the machine out and clean the lint and it will spin and drain. today we have done...
Flood Condition:
Dec 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
