Question about GE Spacemaker JVM1640SJ Microwave Oven
I have ge spacemaker microwave heats but fans dont come on .
I have a ge spacemaker microwave it heats but fans dont come on.
i check the motors resistence and they are good.what should i check?
    Sergeant:
  • 320 Answers
This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Posted on Mar 06, 2009
Spacemaker fan is not working i just chaged the turning motor i thought it was
You didn't mention if the oven heated or not. If not check your door sw
Jun 12, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shorting
From your description the cooling fan is not running, causes! open motor winding, seized motor, or defective door switch, you will need somebody to assess
Jul 19, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I Have a GE Spacemaker over the stove microwave. I think it is 1000 watts. It's 7 years old. Everything works but it doesn't heat anything. There is 23 volts going to the fan unit in the...
HELLO.
Since there is an amount of volts from the outlet, the fault is from the microwave breaker.
The solution is given below.
Reset the microwave breaker.
Take the back cover of the microwave off with a screwdriver.
Inside you will find a motor.
Most microwave motors have a small red reset button on them. Hit that button.
Your microwave should work again if the breaker was the issue.
Thanks
Sep 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turns on but does not heat
if your microwave does not heat up when turned on its maybe the coil is burnt out are fuse broken, so check your dealers
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
191 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
