Question about Canon PIXMA MP830 All-In-One InkJet Printer
On my MP 830 Canon Error on my computer 5C10 Error on printer screen 6A00 Print head moved top the far right and appears to be jammed Had removed and cleaned printhead, reinstalled printhead and inkwells What did I do wrong???
  • 4,041 Answers
Hi
This happens a lot
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Pixma 830 error code 6A00 on printer screen. Error 5C10 on computer screen when trying to print from computer. Tried moving ink tanks back and forth, shut off computer. Moved white thing to unsick ink...
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Mar 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
CANON MP 830 ERROR CODE 6A00
Hi there
Mar 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp 830 all-in-one printer says 6A00,
no need to reset your printer, the things your should do is you just open the over at the back of your printer, then you can see a paper hang on, then please remove it, then try to print, if it does not work open also the tray which is your bond paper stored, just see if there is also a bond paper hang, then remove it, then print again, that the cause of paper jam
 Good Luck!!
 Nice
Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error Code 6A00 on screen , not printing, also on computer screen Error Code 5C10?
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jun 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Alarm light blinking, cartridge carrier won't move
Hi
Ok please try this
Solution 1:
Solution 2:
Solution 3:
Jan 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP830
Hi
Solution 1:
Solution 2:
Solution 3:
Aug 30, 2008 | Canon PIXMA MP830 All-In-One InkJet...
One of two error messages comes on: (1) 5C10 or (2) 6A00, as well as the yellow alarm button and it won't print. I couldn't find anything in the path of the print head holder. PLEASE HELP! Thanks.
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Aug 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
192 people viewed this question
old marine
old marine
