Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Kelvinator air conditioner only works at 29. when i try to lower the temperature it cuts out. any ideas appreciated thanks
  • dcashby Feb 28, 2009
    Hiya
    talking celicus and have got it working again by pushing the reset button
    thanks
  • Farley Redfield
    Farley Redfield May 11, 2010
    Are you talking Celicus? Im used to working in F. COnvert please if so. And are you speaking of the outdoor temp? Indoor temp? How old is this unit? When did it work correctly last? Summer winter?
5 Suggested Answers
  • 3 Answers
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
Posted on May 30, 2008
refritech08
  • 149 Answers
SOURCE: air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Posted on Jun 15, 2008
icemelts
  • 246 Answers
SOURCE: We have this air conditioner in our sunroom. From
I would replace the thermostat.
First - be sure and un-plug the Air Condtiioner from the wall.
When you 'select' the temperture I am assuming you are doing this with a 'knob' of some sort. This knob will be part of the thermostat - therefore it (t-stat) should be simple to identify.
Note: On some - LED/Electronic units - it may be difficult to identify the thermostat.
If, however, you can easily ID the t-stat - then you will have to dismantle the AC unit enough to get to the thermostat; it will be installed on/in the unit with screws of some type.
When you find the thermostat -- simply take the wires off the connections (these are usually - 'female' type spades that slide over 'male' type connections on the switch.
When you remove the wires be sure you mark them in such a way you can replace them on the "correct" terminals of the new thermostat without getting them mixed up.
It will be essential that the new thermostat - (A) physically fit the slot that the old one did, i.e. you can re-install it as the old one was and - (B) that it will have the connections you need - in order to connect your wires correctly.
If you take the old thermostat to an Air Conditioning Supply house they will probably be able to sell you an exact replacement - but in any event - an appropriate replacement - that will work.
good luck!
Posted on May 10, 2010
SOURCE: HELLER MOBILE AIR CONDITIONER
that's the way it should work, after you set temp to 20 degrees, display jump to the inside room temp in your case 25 or 29
Posted on Jun 14, 2010
Power button indicates a cooling mode but I don't hear the compressor come on and the air coming out is not cool. Seems to have worked earlier this summer but sometimes the cooling seem spotty. Tried...
You may not have the temperature set low enough to make the compressor turn ON. Lower the setting until it does. This will give you an indication, where you need to leave it set.
Thanks for choosing FixYa.
Aug 27, 2011 | Amcor ALD12000M Portable Air Conditioner
WILL ONLY BLOW COOL AIR.ALSO SHOULD FAN OUTSIDE BE TURNING ALL THE TIME WHEN IN USE
It is important to set a normal temperature on the AC as a lower setting will make the outside unit to keep working so as to get to the lower temperature.So unless the temperature is reached it will not cut off.
Ideally choose a ramge of 25-27 *C for the room as the normal room temp ideal for humans is 28*C.
Aug 12, 2011 | Heating & Cooling
I have an Everstar portable air conditioner Model MPA-08CR but when it is working for 10 minutes...it is working fine cooling the desired space but the next 10 minutes it is only working like a fan...then...
The problem may be that you don't have the temperature set low enough and the unit reaches the set temperature quickly and then only the fan runs. Try lowering the set temperature.
Aug 05, 2011 | Heating & Cooling
Have a Amana Wall Unit with Heating and Air Conditioning - Model PTC123B50AE. The unit's heater just stopped heating. The fan/blower and air conditioner are working fine. Unit says the fuses are OK. ...
PLEASE CHECK THERMOSTAT SETTING +29 AND ALSO MODE"HEAT". STILL PROBLEM CHECK THE HEATING SENSOR IS NOT OPENED. BY A OHMS METER CHECK THE SENSOR. iF ANY READING IN OHMS IT'S O.KAY.
Dec 13, 2010 | Heating & Cooling
Jun 10, 2009 | Haier Heating & Cooling
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Oct 16, 2008 | Heating & Cooling
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
350 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
