Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso GVW9959K, what buttons do u press for control override
On the Kenmore CalypsoGVW9959K there is a FL code. I think there was a SL prior to this and my wife restarted the washer in a rinse and spin cycle. We have had Sears technicians before on numerous occasions and I learned a nifty trick where by simultaneously pressing two buttons you can override the control panel and run/test the pump.
Can you provide the simultaneous button pressing sequence.
Thanks in advance.
Mark
    Scholar:
  • 106 Answers
Try 'spin' & 'drain' together till the code clears.
Posted on Feb 27, 2009
Error FL
FL= Flood Condition
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for FL to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Note: Press STOP/CANCEL to clear display on all error codes
Causes of flood condition. Inlet valves stuck on, sediment in water level pressure tube, water pressure tubing vibrated off the switch. Bad switch (highly unlikely).
Other codes:
PF power failure
Er control lost settings during PF
LF Long fill Clogged inlet screens
CE Com error between motor and control
Ld Long drain Clogged/slow drain/pump
CA/CI Motor amping up
ob off balance load
Sr relay failure no control to motor
LS Lid switch no signal from lid switch, error occurs if the motor and control disagree as to the position of the lid switch. Usually means corosion is buit up in the switch and the motor knows the lid is shut but the control does not. Code appears when start button is pressed.
open lid= flashing display time If the lid is opened time remaining flashes in display. Close lid and press start to continue.
SL Suds Lock Current draw on motor is sensed by motor control and a suds lock is declared. The control trys 3 times to fix this by doing a mini cycle, SL is displayed if the unit was unable to correct the problem. This problem is caused by:
Bad pump
Extra heavy load
Excessive detergent
or Excessive suds/wrong stuff
Last summer me and my buddy Robert worked on a one of these and took some pix:
CALYPSO REPAIR MANUAL AND SOME PHOTOS
Feb 19, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Just replaced the motor and pump, 3 weeks ago.
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$
May 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Just replaced the motor and pump, 3 weeks ago. Now I am getting an ld and then an FL?? Calypso Kenmore washer Elite
Flood Condition:
Mar 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore calypso wont rinse and displays the fl code.
Flood Condition:
Feb 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso displaying SL or5L messages, did you get it fixed?
I see at least 2 of these a week. 9 out of 10 times, it's the pump. If the u-joint is bad, it will put strain on the motor causing it to think it's overloaded as well.
Jul 12, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
194 people viewed this question
Dan Webster
Dan Webster
Sal De
