Question about RTO Hubbard Supply Co 250 Up to 1" CTS Pipe Sizes
Pipe sizes What size copper pipes is used for a 9000 BTU split unit.
  • jandrevdh Feb 27, 2009
    What is the sizes with which the airconditioner is sold.
  • 10,865 Answers
Depends on the distance between the source and the unit
Posted on Feb 27, 2009
What is the size of the gas line piping on the out door unit of a elite elegance split unit
You need size of pipe , length of run , input of btu.s you need all this before you can size pipe
Jan 18, 2017 | Heating & Cooling
My wall split a/c 24000 btu work about 1 hours or more after no cooling and u can see frost in the indoor coil and on the coppers on out door unit and i have low pressure 40
Low pressure and frost on your indoor coil with the copper pipe to your outdoor unit is almost guaranteed a low refrigerant charge. It can also be a bad metering device. You will need to check you high and low side pressures to be sure and make sure you let the frost thaw before checking pressures.
Nov 16, 2013 | Heating & Cooling
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
What diameter size galvanized pipe do i use for installing my new Raypak 266,000 btu gas heater?
Refer to the owners manual as the pipe size is dependent upon the length of run the pipe will be, the pressure your fuel system operates at and the fuel you'll be using. If you do not have the manual you can find a copy here. Refer to page 20.
John
Jun 05, 2011 | Raypak 2100 Pool Heater Gas 266000 BTU'...
What size gas line for 400,000 btu water heater
Thank you for posting your question here on Fixya.com.
Is it Natural gas or LP gas?
What pressure does your gas provider supply it with? (It will usually be low pressure, ~14"WC if NG)
How far from the access point you will get gas from to the heater?
Once you have answers for these three questions use the installation guide found on pages 13-14 of this manual to determine the proper gas line size. Be sure if you use a different material pipe, like CSST, you adjust the pipe size based on manufacturer's recommendations. 1" copper and 1" CSST are NOT equivalent!
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Feb 12, 2011 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Wansa split a\c outdoor unit both pipe size
It depends on the make model of your unit , the capacity of the unit. It will be best to check the pipe sizes that are on the outdoor unit and the indoor unit that needs to be connected.
The copper pipes can then be decided after checking the length of your fitment.
Jan 08, 2011 | Heating & Cooling
We would like to connect an imperial us copper pipe to an Australian copper pipe. These are water pipes in peoples homes. We are using the imperial standard, which is a bit different from the Australian. I...
they make a piece that fits numerous sizes of pipe, it just slides on, at the Home Depot I think they are called the Gator Bites, lowes has similar but doub't know the name, you have to know what size you are close to ie 1/2 , 3/4 etc
Dec 18, 2009 | Plumbing
How to tell the size of my ac unit?\
thats a 5 ton ac unit
10AJA6001AH
basically 1 ton = 12,000 BTU
so 24 is 2
30 is 2 and a half
etc
Jun 21, 2009 | Weather King Heating & Cooling
Oil trap for 2 ton split unit
Pipe size is okay, not that I know any better than the manufacturer, but I would recommend at least two and possibly even three oil traps in the vapor line on the way back up.
Jun 14, 2008 | Heating & Cooling
RTO Hubbard Supply Co 250 Up to 1" CTS Pipe Sizes Logo
88 people viewed this question
Top RTO Plumbing Experts
Tom Chichester
Gil Shultz
Are you a RTO Plumbing Expert? Answer questions, earn points and help others
