Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Bobbin winding bobbin does not want to wind up, gives an error but no error code. Otherwise machine works perfectly.
  • 10,865 Answers
Http://www.singerco.com/accessories/manuals.html
go to this site and you can request the owner manual which will shoe u exactly how to proceed
Posted on Feb 27, 2009
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
How to load bobbin?
Hai, Please What is your sewing machine model? Because some model machines attached bobbin winder with machine . Otherwise you winding a bobbin to your machine for side upper wheel. Or Please see the link : How to Wind Bobbin
Mar 30, 2014 | Sewing Machines
Singer stylist E2 error code bobbin winding
I have just repaired a 7258 with a frozen bearing unrelated to the E2 code except that I thought I would lube the entire machine while it was apart, and through my ignorance, I greased the clutch that releases the mainshaft when winding the bobbin, and then when the clutch wasn't working correctly, caused the E2 error. I can say the E2 error is not caused by a plug not seated correctly, too much tension in the bobbin thread, or God having a bad day. The E2 error code is thrown when the bobbin holder is in the wind position, and the mainshaft rotates. There is a clutch just behind the hand knob on the right side of the machine, and if it has too much lubrication with a stiff grease, or on an older machine, if the lube has dried out, the clutch will not release properly. I took the clutch apart, cleaned the grease I put in it, and then lubed it with bicycle silicone oil. It now works as designed. The hardest part of the repair was figuring out how the plastic cases split apart! If anyone in the SF Bay Area has a 7256, or 7258 that gives the E2 code, I can fix it - it's actually kind 'a fun...
Feb 08, 2013 | Singer Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Myfriend has a Juki tl 98 Q on a frame. hooked up to the gracey sure stitch regulator. How do I wind a bobbin without having to unhook everything and put the foot foot petal on to wind a bobbin?
Simpliest solution is to buy a stand alone bobbin winder so you can wind them anytime. You can get one from http://www.sewingpartsonline.com/universal-automatic-bobbin-winder.aspx .
Otherwise you would need to wind enough bobbins before you start a project on the frame I guess.
Mar 13, 2011 | Juki TL-98Q
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
My bobbin isnt winding correctly
re-thread sewing machine for bobbin winding. There should be a screw looking thing that holds the thread taut while threading
May 26, 2010 | Euro-Pro Shark 60 - 384
Display will only show "Bobbin Winding"
Presumably you have turned the machine off, and then back on again to, in effect, reboot the machine's computer?
The only other suggestion I can think of, is to ensure that the bobbin winding post is FULLY to the left when you want to sew.
It may be worth looking around the bottom of the winding post to see if there is any build-up of thread (or other stuff) that is preventing the post going to the fully-left position.
Apr 09, 2009 | Janome Memory Craft 9000 Computerized...
Winding the Bobbin
I have the same problem and was skeptical of the drop of oil solution but it worked. I had taken my baby lock ellure apart while investigating previously and found nothing else wrong. Tried a few drops of oil and after a moment it started winding noisily and then settled right in!! Working perfectly now!
Jan 20, 2008 | Baby Lock Ellure
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
155 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
