Question about Acer Aspire 5920-6727 Notebook
Acer aspire 5920G will not turn on
We checked the current and power is getting to the board, but no blue light is on and it makes a quite clicking sound
    Genius:
  • 1,847 Answers
It seem issue with the memory card, try reinstalling the memory card and then try booting.
Posted on Mar 03, 2009
Acer won't charge or turn on
Yes. You need to replace one or two Power MOSFET's,
1) Using the HP Pavilion dv6000, and Pavilion dv9000 series of Notebook PC's; as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Example of Fairchild Semiconductor International (Inc) -
FDS6679 - Power MOSFET, and Alpha & Omega Ltd -
AO4407 - Power MOSFET, plus price;
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMshyDBzk1%2fWi1qxDdW%2fXBi2qgMuZEfLVO4%3d
Obsolete. Cross reference replacement FDS6679AZ - $1.01 USD
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
Obsolete. Cross reference replacement DMP3020LSS-13. 78 Cents USD.
http://www.youtube.com/watch?v=3NN7UGWYmBY
http://www.youtube.com/watch?v=5uiroWBkdFY
No?
Then suggest YOU replace the motherboard. Less cost, and a learning experience,
Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the 'paragraph' that starts with Aspire 1200. (1200 in blue)
Drop down to the 10th line (5738ZG), scroll across, click on the blue - 5920G
[Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (5920G) it may take up to 30 seconds, before the first page comes up.
The PDF file will not show until fully downloaded ]
The following pictorial disassembly guides are not your laptop, but feel they may help if you see a 'hands-on' approach,
A) http://www.insidemylaptop.com/take-apart-acer-aspire-5820t-series-laptop/
B) http://www.insidemylaptop.com/how-to-dismantle-acer-aspire-5534-series-laptop/
C) http://www.insidemylaptop.com/disassemble-acer-aspire-7551g-laptop/
This one is for an Aspire 5920 series of Notebook PC.
Not very good video quality, fair.
Suggest start at 3:03
USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
(Electro Static Discharge)
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or perhaps a large metal knickknack (Unpainted)
Average cost of an ESD wrist strap is around $3 to $6. Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Use a multi-compartment container, for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws!
Advise do NOT mix them up.
Take photos, or use a video camera if available. Use good lighting.
Make notes if you need to.
Have a personal record of what YOU did to refer back to, instead of just a Service Manual, and/or instructionals.
Just an idea.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Acer Aspire 5920-6335 Laptop
Have an Acer Aspire 5920G that is dead. The power supply seems OK with the green light on and ~19 VDC on the DVM when checked. no power light on computer when plugged in, with or without battery.
It is possible that there is a problem with the connection from your power supply going to the main board of your laptop.
This is rather a technical problem and my best recommendation is to bring your laptop to a technician and have them check it.
Hope it helps!
Thanks!
Feb 02, 2011 | Acer Aspire 5920-6727 Notebook
Acer will not turn on. The blue power light comes on but it doesn't make start up sounds and screen is blank.
Melissa I had the same problem with my two daughter's Aspires. You'll have to get onto Acer's website www.acer.com.au/helpdesk (Australia) and download 6 pages of "Updating the Bios on the Aspire One". You will need a flash (thumb) drive no larger than 2GB to boot your Aspire eventually. I'm currently having problems with the batteries not charging at all. Don't know the solution yet, but if this ever happens to you, don't go out and buy a replacement battery like I did. The battery still isn't recognised. Hope this helps you in some way.
Derek
Nov 03, 2010 | Acer Aspire One PC Notebook
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with...
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Aug 20, 2010 | Acer Aspire 5920-6727 Notebook
ACER 5920g needs to stay on when lid closed
Plug first you computer o rather laptop to your TV with the right cable then right click to your desktop. Select properties then select settings then in the display drop down box choose number two click apply and hit ok.
Then before you close the lid...hit FN (color blue key) then hit f5....it will switch to your LCD to your TV. Enjoy.
Jun 05, 2010 | Acer Aspire 5920-6335 Laptop
Acer ZD1 aspire 5920G will not turn on
could be the motherboard that is gone, could be the power board inside, my wife had a similar problem of the power going to the board, but not charging, needed a whole new motherboard
Feb 27, 2009 | Acer Aspire 5920-6727 Notebook
Hi, I have an Acer Aspire 5920G. My problem is when the laptop is switched on it sounds like it's booting but the screen stays blank? Have you any idea what can cause this? Regards, Dan Pook...
Hello
I think your graphics card or screen is broken on your Acer Aspire 5920G, one thing you can test is to connect at external monitor to your laptop. If you dont get any picture then its your graphic card broken, if you get picture it is your screen. also try to adjust the screen light.
Sep 15, 2008 | Computers & Internet
BSOD on a acer 5100 laptop
I was unable to turn my acer aspire 3690 on no matter what I tried the lights came on and the fan ran but no monitor no sounds.... searched the internet and reboted ect... Did you know acer aspires (mine at least ) has a screen lock? try pressing F12 and fn duh! I thought the mother board was shot.... my 4 year old had locked me out of it! Much easier than replacing the mother board huh?
Mar 11, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5920-6727 Notebook Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
