Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Intermatic timer T101
My timer sets 10 PM to 10AM. now, i want to set it 5PM to 5AM.
can someone teach me how to do and set the on and off tripper . to set the right time now. i dont know how. i have no manual to follow directions. do i have to use fliers to tighten the screws ? kindly help me
thank you.
  • 8,197 Answers
This link should help you set timer.
http://www.intermatic.com/images/instruction_sheets/T101.pdf
Good Luck and Please Rate FixYa!
Posted on Feb 27, 2009
How do I set T101 intermatic T101 timer to 7:30 PM
PROGRAMMING INSTRUCTIONS 1. TO SET "ON" AND "OFF" TIMES: Hold trippers against edge of CLOCKDIAL, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A. 2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
http://www.intermatic.com/-/media/inriver/10162-9164.ashx/T101-Instructions-EN
Mar 23, 2017 | Intermatic Hardware & Accessories
I have a timer hooked up to operate my outdoor landscape lights so that they come on around dusk and turn off at 11 pm or so. The "on" tripper which is white clicks as the timer rotates past the...
Sounds like the OFF tripper is worn down.
Timer needs to be replaced unless you have Intermatic-brand timer.
Intermatic is only company that sells plastic replacement trippers for their timers.
Except Intermatic on-off trippers are typically red-green.
It's possible your trippers faded in color.
Open following links to identify Intermatic timer and tripper:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
Sep 18, 2011 | General Electric Hardware & Accessories
I need trippers for timer paragon 4001-00m
1) Paragon is no longer making X2772 trippers for the 4000 series timer.
Some places may still sell the X2772 tripper.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
2) I saw X2772 trippers for $60 spring 2011. And the ad did not say the trippers were new.
3) Buy replacement T101 Intermatic timer for less than that.
Example at Amazon showing T101 indoor timer: For outdoor timer, buy T101R.
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
4) Crossover wiring from Paragon 4001-00 to Intermatic T101:
Paragon terminal 1 goes to Intermatic 1
Paragon terminal 2 goes to Intermatic 2
Paragon terminal 3 goes to Intermatic A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
5) Add a comment for more help
6) Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Hardware & Accessories
I need a set of trippers for a Paragon timer Model number 4001-00. Where can I get them. Thank you. My name is Jim Vivone
Google search for X2772 tripper and some places may still have them.
Paragon is no longer making timers and parts except defrost timers.
Paragon 4001-00 120Volt timer uses X2772 tripper:
Paragon 4001-00 crossover to Intermatic is T101 120Volt timer.
Crossover wiring:
Paragon 4001-00 has terminals 1 2 3
T101 has terminals A 1 2
Paragon terminal 1 connects to Intermatic terminal 1
Paragon terminal 2 connects to Intermatic terminal 2
Paragon terminal 3 connects to Intermatic terminal A
Aug 03, 2011 | Hardware & Accessories
Where can I find the timer triper set for a paragon 4001-0g
Open following link to identify timer and download manual
1) Paragon 4000 series uses X2772 tripper.
2) Internet search for tripper reveals some sources selling set of trippers for $50.
Paragon is no longer making timers or parts, except for defrost series timers.
4000 series is not a defrost timer, which explains high price for trippers.
Some sources might still have X2772 tripper at lower price.
3) Other companies are still manufacturing some Paragon timers for niche sales.
Certainly the Paragon line is still active although names and numbers will probably change over next few years.
4) I cannot specifically identify 4001-0g, and the 'g' suffix does not show in sell sheet
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
5) Replacement timer for 4001-00 is Intermatic T101
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
6) New T101 from Amazon is $45.00 with free shipping
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 23, 2011 | Paragon Hardware & Accessories
I need a set of trippers for a Paragon 4001 switch timer. Need both "On " and "off" trippers. Can you find some?
Paragon 4000 series timers uses X2772 tripper
Google search x2772 tripper
Frontier Lighting shows they are out.
A couple other places show 56-60 dollars for the tripper
In November 2010, I got e-mail from Paragon saying that Paragon stopped making timers and parts for timers, except for defrost timers. 4001 is not defrost timer.
Intermatic has cross-reference link if you want to buy new timer:
Cross reference shows T-101 timer matches your timer.
Aplus supply sells T101 for $60
http://www.aplussupply.com/intermatic/timer.htm
Amazon sells T101 for 43$ with free shipping over 25$
T101 wiring:
Jan 07, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
I HAVE AN iNTERMATIC t100m TIMER it appears to have two "off" tripper levers but no "on" tripper lever attached to the clock face dial by a set screw . Do I need an "on "...
Yes, the T101M 120Volt pool timer requires both ON and OFF trippers:
Grainger sells T100 series on-off trippers:
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Amazon sells T100 trippers
http://www.amazon.com/dp/B003YO2C5U/?tag=picc-20
Grainger sells the T100 125V clock motor
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T-101 120Volt timer
How Intermatic dial timer clock works.
Clock motor rotates dial.
Intermatic clock motor, located on back of mechanism, are replaceable
Trippers located on outer edge of dial push on-off lever
ON tripper pushes lever one direction
OFF tripper pushes lever opposite direction.
Lever pushes electrical contacts together and pulls contacts apart.
When lever moves, manual override also clicks back and forth with audible click.
To replace timer, replacement snaps into box without needing to changing box.
Dec 10, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
I have the Intermatic T101 24 Hr. The light come on fine but the clock stops at that piont and the lights stays on.
Does the clock stop, or does the light just stay on? Without knowing any further information, you have a tripper that is set for the time to go on...now, you should have one that is set to go off. Make sure you have both trippers set, and working. (ie. set one to go ON at 8:00 pm, and the other to go off at 8:30 pm). If so, then set them to your desired times - and try again.  Also, I'm not sure how long you've had this timer - because you could have a bad motor. If so, it's cheaper to buy a new timer - than try and buy a motor for it. Anyway, try the above information I gave you - and then let me know what happens. Any other information you can give me would be great. I hope the above info. helps you, but if not - we'll try Plan B. Good Luck! - JR
Jul 02, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
461 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
