I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.htmlAlso run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
