Question about Dell Inspiron 2200 Notebook
My laptop went into hibernation, due to a low battery. so i plug it into the wall just after a few minutes it died and wont come back on
  • Anonymous Mar 01, 2009
    laptop shut off low battery now won't turn on
    Problem Solver:
  • 10 Answers
Did you tried it on after pluggin the power cable ? or without power cable ?
try to remove your battery and refix it. or else just open your backcover and remove your ram's and refix them it will work for you :)
Posted on Feb 27, 2009
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
I have an acer one, and it went into hibernation, and now it wont come out, when i hold the power button a blue light flickers above a light bulb on the key bored, but for some reason it wont come on
I would remove all the power--that is, unplug it from the wall and take out the battery.
Wait a couple of minutes and replace the battery and, if you are using it with the computer plugged in, plug it in again.
This was a common problem with Vista when it first came out.
Sep 23, 2011 | Acer Aspire One Netbook 8.9" Notebook
Computer will not power up..Upon initial start , went into hibernating mode then never started up.
Hi
Please can you try the following
1) Remove battery and wall charger
2) Press and hold the power button down for 30 seconds
3) Plug charger and battery back in
4) Retry powering the laptop
Regards
Shauqat
Apr 19, 2010 | Sony VAIO VGN-S460 Notebook
My new hp mini laptop went into hibernation while I was typing and it wont wake up I have tried taking out the battery and replacing it and plugging and unplugging it but dont get any response from it.
Thats not hibernation it sounds more like death!
Only a pc workshop can analyze faults like this....you may have to spend a few bucks ....but hey.....if it;s worth it you will do it I guess!
Oct 20, 2009 | HP Mini 1000 Netbook
My lap top says my battery is low yet I have it plugged into the wall. It then proceeds to hibernate after a minute or two. What is happening?
Remove the battery and connect the laptop to the powersupply (and wall offcource) and see if it will do the same. I think some cells in your battery are broken and therefor will not charge enough. This can give problems with windows.
Jul 07, 2009 | CMB T43 750 Notebook
LAPTOP NOT TURNS ON
This is probably due to a bad battery or damaged powerjack. Does the laptop work when connected to a plug point?
Sep 28, 2008 | Computers & Internet
Lenovo 3000 N200 battery wont charge
no it might not be a battorey problem it could be a software problem,
Sep 11, 2008 | Lenovo Computers & Internet
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
Amilo pro v7010 laptop wont switch on
If so, unplug it from the wall charger, remove the battery and wait 5 minutes. Then plug the unit back in, leaving the battery out. Attempt to power up. You may lose what work you hadn't saved from the previous use, but nothing else.
If that doesn't work, it's possible that
A) power socket isn't completely connected to the motherboard anymore, so
B) battery isn't charging properly, or
C) the wall charger has gone bad.
I'd say you're in hibernation tho.
Good luck
Nov 25, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Dell Inspiron 2200 Notebook Logo
53 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
