Question about Mitsubishi VS-50609 50" Rear Projection Television
Sony KDS R50XBR1. No picture, no sound
3 year old Sony KDS R50XBR1. 6 months ago optical block replaced. Now suddenly, no picture, no sound, nothing. When turned on, green power light flashes for 1 1/2 minutes twice a second then turns red. It then flashes continuously once a second. No pauses, no pattern, no code just continuous flashes until the remote power key is pressed. Then it goes back to green and if pressed again, power goes off. What do I do.
  • EDTF Directo Mar 21, 2009
    Green light goes on when turned on then red light flashes 4 times. No picture No sound. A tech thinks it might be the ballist since I replaced the lamp 5 weeks ago.
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Posted on Jun 01, 2006
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
  • 479 Answers
SOURCE: I fixed the blinking light, but still no picture
check for any moisture still left on the board.also cold solder the whole board.
Posted on Oct 04, 2008
SD Tech
  • 14553 Answers
SOURCE: We recently experienced a power outage, but once
The blinking green light is the DM unit in the set booting up like a computer.
Several things can happen here--Research by model number with GOOGLE, model number and problems.
It is often called the blinking green light of death.
The most common problem is 4 filter caps in power supply (they run 7/24 and supply voltage to DM unit fail--also some fuses there.
If you look on the net you will find places that sell kit for this repair.
This is also one of a group of several Mitsubishi sets with this kind of problem--It is not the Lamp!
Some of these models develop so many problems Mitsubishi now sells a chassis replacement--includes power and several boards that develop bad caps.
Understand: Mitsubishi has a long history of caps failing in their sets, it goes back almost 30 years. I have seen older ones where over 20 filter caps were bad.
You can talk to Mitsubishi to see if chassis replacement is available for your set--this came about as a result of the threat of hundreds of people entering a class action lawsuit (several).
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions make a "comment" here and I will assist you.
SD TECH
Posted on Aug 24, 2010
Testimonial: "This is somewhat helpful. I'll contact Mitsubishi. Thanks!"
SD Tech
  • 14553 Answers
SOURCE: Green power light flashes 2 times pauses, flashes
Short protection--98% chance one of the two fuses that protect the convergence circuit is blown. Repair requires replace fuse AND CONVERGENCE OUTPUT CHIP/S I Have start to finish instructions for this repair (parts cost under 25 dollars) let me know if you want the instructions and we will get them to you. SD TECH
Posted on Sep 07, 2010
Testimonial: "Very helpful. I was almost sure I had a power supply problem. "
Have a Sony TV modelKDS-R50XBR1 and after changing
Required optic block part number is A1148155A for KDS-R50XBR1, commonly calls light engine. Available HERE and HERE.
Click above links for price info.
Thanks.
Jul 30, 2010 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 optical engine problem
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 27, 2010 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
My tv is screen is green
Sounds like your optical block neeeds replaced, my kds-r50xbr1 just started getting the yellow-green haze who knew $3000 t.v's would only last 2 years urghh check out this link to sony and call the (866) 850-8674
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR50XBR1&news_id=219
Apr 15, 2009 | Sony KDS-R50XBR1 50" HDTV
3 year old Sony KDS R50XBR1 suddenly no picture, no sound
MY SONY KDS-R50XDR1 TV ITS PLAYIN GREEN THERES NO BLUE HOW CAN I SOLVE THIS PROBLEM.
Feb 10, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50xbr1 50" Problems
Here's the best way to get Sony's and/or the extended warranty company's attention and possible help.
Send an old fashioned letter to Sony and your extended warranty provider outlining the problems and your concerns regarding your TV. Make sure to prominently indicate that a copy of the letter is being sent to the complaint division at the attorney general's office in your state. After having to settle claims surrounding their optical block (light engine) issues Sony now understands that failure to address their customer's complaints may result in another judgement against them.
Good luck and give 'em hell!
michtech
Jan 27, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 9 red blinks
Isn't that the idicator telling you that its time to change the dlp lamp?
Jun 28, 2008 | Sony KDS-R50XBR1 50" HDTV
WEGA only show yellow
Hello watts74:
When you turn your tv on, you still get an image of whatever channel you are on, but the background on the entire screen is green/yellow, correct? If so, the problem is the optical block. Read what I posted below on another thread and you should be on your way to getting your situation resolved.
Here is the link to the other thread I mentioned: http://www.fixya.com/support/t157434-green
All the best...
By nonexpert_s.gif KDS-R50XBR1
Rank: Apprentice
Rating: 0%, 0 votes
If your SONY KDS-R50XBR1 or KDS-R60XBR1 color screen suddenly turns green, the optical block (aka light engine) is the culprit. Don't fret because as "Leadtech" has already posted back on Jul 04, 2007, SONY is aware of this problem and has extended the warranty to replace this very part. Additionally, and aside from the class action lawsuit currently pending in district court, parts and labor for in-house service IS included.
SONY states the warranty as follows:
"As part of the Sony commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor), in the United States, on the optical block of KDS-R50XBR1 and KDS-R60XBR1 model SXRD televisions until October 31, 2008, regardless of purchase date."
So all you have to do is:
1) Contact SONY Customer Service at (800) 222-7669 or (888) 772-7669 - Hours: Mon-Fri 9:00AM-10:00PM / Sat-Sun 10:30AM-7:15PM EST
2) Provide them with your model (as above) and your television's serial number
3) Tell them your screen color is nothing but green
4) They will provide you with a case number
5) They will ask you for your zip code and provide you with one or more SONY authorized service dealers, and their contact information.
6) You contact the dealer of your choice and schedule an in-house service. Explain to them that your screen is green and you are aware that many, same tv-model owners that have had this same problem, and that the optical block is the problem.
7) The SONY authorized dealer you speak with will schedule and appointment with you, and will provide in-house service.
Regarding the service, it will take about an hour to complete. Not that it is complicated for the technician, but where the optical block is located is that is time-consuming. It sits just "behind" the bottom of the tv screen and in order to get to it, the technician will have to:
1) Remove the bottom back gray cover
2) Remove the replaceable projection lamp located on the left side of the tv (looking from the back)
3) Remove lots of phillips screws
4) Disconnect many plugs
5) Remove 3 chassis closest to the back of the tv before getting to the optical block chassis, which is located up front, just behind the tv screen
Once the optical block is replaced, you will be amazed on correct color results.
Hope this helps...
Oct 15, 2007 | Sony KDS-R50XBR1 50" HDTV
Mitsubishi VS-50609 50" Rear Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
