Question about HTC G1
G1 charge light is not on but the phone is charging
    Scholar:
  • 93 Answers
Had a similar problem on my HTC (same maker of the g1) touch diamond, the charge light/indicator would stay on even after i took the cable out.
It could be just lag. Try doing a soft reset, where ever the reset button is on the G1 (Inside the back case?) If that doesn't help do a hard reset which deletes all data/settings (other than your carriers settings, your phone will still work), you would have to look in your manual, as I dont have a G1.
Posted on Feb 27, 2009
  • Denis K. Feb 27, 2009
    If neither work, then its a internal hardware problem, and you would have to get it looked at by HTC, if you still have a warranty, or open it up your self, if your willing to risk damage to your hardware..
SOURCE: g1 Phone Wont Charge
take the batteries out and put it back in again and try charging check in diff power sockets press the end of the charging cables with little amount of pressure and have a check try to connect via the usb cable to the computer and check if it charges, if works the charger is faulty if still did not work then it will be firmware problem with of phone
Posted on Nov 03, 2008
  • 22 Answers
SOURCE: my g1 will not charge fast like it use 2
Have you tried recalibrating the battery? To do this you use the phone until it completely runs out of battery and switches itself off. Make sure it has completely run out by continuing to turn it back on until nothing happens except a red LED coming on. Then charge it while it's off until the green LED has been on for 2 hours. Hopefully this will improve your battery life.
Posted on Jun 15, 2009
SOURCE: Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Posted on Jul 19, 2009
Tarrzn
  • 35 Answers
SOURCE: My g1 phone doesnt charge
Also, try checking the battery, on this phone you should be able to take the battery out of it and run straight to the board bypassing the battery.
If the phone turns on, great, you just need a battery. If it doesn't, you're probably have a bad circuit board/broken charger port. Take it to your nearest phone guru for repair if so.
Otherwise, keep Android'n :-)
Posted on Nov 20, 2009
  • 26 Answers
SOURCE: my T-mobile G1 wont come on, it wont charge.
it's your charger get a new one it happen to me
Posted on Mar 12, 2010
I bought my g1 about 1 month ago and now its just slow, draining battery fast, and getting really hot. anyways one night i left my G1 on my desk next to a cold ice bottle of water and the next morning my...
the mobile requires a service with solution dipped in liquid, as few resisitors and capcitors might have been still corrosive, i think you please leave the phone without battery in room temp of 26-30 deg ... for a day or two...
Jun 16, 2011 | HTC G1
Wont charge. i plugged into so many usb cables and box chargers and light wont turn on nothing charges it
Your charging port is probably bad. It is a common issue. You can take it into an electronics shop and they could fix it by sending it to the manufacturer, but it might cost more than a new phone like the HTC incredible
Mar 01, 2011 | HTC G1
I am trying to charge my phone right now but it is just a constant red light where it would usually be orange and it is saying 0% charged
did you run the battery completely flat?
my phone if it has gone dead, when plugged in to charge, has a red LED for about 5 minutes where you cannot even turn it on it is that dead. after those minutes pass the phone can then be turned on, and the LED changes color to orange to indicate it is charging and is also powered on.
Jul 12, 2010 | HTC G1
((G1 Will Not Turn On)) When The Fone Is Off The Charge Light Shows But Will Not Come On
your phone's charger may be broken. the red light also indicates a dead battery or needs charge immediately. try using another usb charger to see if it works.
Aug 12, 2009 | HTC G1
My g1 will not charge fast like it use 2
Jun 10, 2009 | HTC G1
Blue On G1
Mar 05, 2009 | HTC G1
Speaker on g1 phone stopped working
Well first of, there is your warranty, but if your phone breaks after expirations, there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, so there is no need to worry.
Feb 02, 2009 | HTC G1
G1 charging issue
Blame it on weather maybe, I have this problem often. I found that if you don't try and charge it ALL the time, it may work better. I have even created a cradle to keep it from moving while charging.
The car chargers have this problem more.
Let me know if this helps.
Jan 24, 2009 | HTC G1
G1 Phone Wont Charge
Nov 03, 2008 | HTC G1
HTC G1 Logo
656 people viewed this question
Top HTC Computers & Internet Experts
Justin
Justin
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
