Question about Canon MultiPASS MP370 All-In-One InkJet Printer
I have a Canon MP370 printer. I have changed the black ink (used three different cartridges)but it is not printing. It does print in colour. I have cleaned the head, realighned etc, disconnected and reinstalled from disk reconnected but still not working. Can you help me please.
    Problem Solver:
  • 10 Answers
Yaa thats your black Print Head is not working, you need to get it replaced by new print head.
thats only solution.
Posted on Feb 27, 2009
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
Hello there, i have a canon MP370 which i have been very happy with and had no problems,however the machine when it prints now all the colours are very faded and banding occurs right accross...
Check your cartridge first and take a look if it is not running out of ink,try replacing it with a new one then on your printer maintenance do head cleaning,then print nozzle check to see which color has a problem,if it doesn't change try to look for chemical solution that are being use to clean print head. soak the print head,dont touch the head with your bare hands or anything hard its sensitive.
Sep 12, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Printer will only print in colour ink, not anything in black text
The issue your having is more then likely the ink cartridge itself or the printhead. Here is the steps in checking and possibly fixing the issue. Step 7 though should be done by a repair tech.
(1) Check that the orange cap or tap is not on the printhead.
(2) Remove the printhead and re-install it.
(3) Perform printhead cleaning, and visually check the test print for non-discharge of ink from nozzle.
(4) Perform head-refreshing, and visually check the test print for non-discharge of ink from nozzle.
(5) Replace the appropriate ink tank.
(6) Replace the printhead
(7) Replace the purge unit.
Jun 18, 2009 | Canon Office Equipment & Supplies
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mp370 nnot printing color even after changing ink tank
take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Nov 21, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
344 people viewed this question
old marine
old marine
