SOURCE: Euro Pro 9105 won't catch bobbin thread
First make sure the needle is in the machine correctly- all the way up into the needle bar and that it is threaded correctly, etc
If this all checks out ok, take the bobbin case out of the machine. There are two ears on either side of the bobbin case- turn the left one to the left and the right one to the right. Remove the silver ring, and inspect the piece of metal that the ring came off of (looks like a circle with the top cut off). You have to locate the hook which is the piece that looks like a half moon inside the big round metal piece. Locate the tip of it, turn the handwheel toward you until the needle is in the lowest position, at this point the tip of the hook should be flush with top of the left side of the cut off circle. If this is not so, your machine needs to be re-timed which can be done from the bottome of the machine usually.
Let me know if you need any help with this
SOURCE: How do I keep bobbing thread from bunching on model 375?
You can get a PDF manual for this model on the Euro Pro website, to show you how to thread correctly and more
SOURCE: i have a new sewing machine, Euro pro 373stitch help
You can download the manual here.
http://homeappliance.manualsonline.com/manuals/mfg/europro/373.html
Good luck and please rate
SOURCE: how to thread euro pro serger
If the thread guide in printed on the side of the door or on the machine, you will need to follow the threading sequence.
Turn off the power.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the serger has automatic tensions, raise the presser foot as this also opens the tensions.
Turn the handwheel so the loopers are at their highest position.
Begin threading from the right to the left - lower looper is usually the first to be threaded.
After threading, set the tensions back to the normal setting and stitch a chain of thread and it should be knitted/interlocking.
Click the link on the right-hand side of the page below the text box, which reads "Customer Service: Click Here." This will direct you to a contact page.
