Question about Whirlpool LSR5132PQ Top Load Washer
Whirlpool LSR5132PQO not working
My washer is not working thet all firs the stop not drawing now it not washing the cloth stil thery
  • 686 Answers
And also the "drive motor to transmission coupling" is probably broken. You need a repair person.
Posted on Apr 06, 2009
Hello, after the first fill it will trip the circut, I have tried what I believe to be a different circut with the same result. Washer still full of water, please help.. Thank you for any help. Model# ...
Check to see if this may be caused by a Ground Fault Interrupter. If water has gotten into the electrical system of the machine, this will continue to trip until the fault location has dried out and no longer causing electrical leakage. If this is a standard breaker that is tripping, this would mean you have a shorted motor causing it to draw excessive current.
The combination breaker/GFI can itself fail; I replaced several of these after only a few years of service.
Aug 08, 2011 | Whirlpool Washing Machines
My Whirlpool Cabrio top loading washing machine stops with an error OL . nothing wrong with the loading, this is only a small whash. Where is located this sensor for overload?
The sensing is done by measuring the motor amp draw. If the motor amp draw is high that is an indication of a heavy loaded washer which could cause the motor to overheat OR too much soap being used, OR the wrong soap being used, OR something between tubs. If you is getting an OL and the clothes is not the problem then you may have an item lodged between the tubs. You must remove the inner tub and get that thang outta there. Cabrio service manual
Rate it or hate it!
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
if the spin speed is slow it could be the clutch is worn out.
Mar 21, 2010 | Whirlpool LSQ8000 Top Load Washer
Whirlpool Duet 9150.. should I be able to see water in the tub when it is washing? There is no visible water level. The clothes are wet but how do they get clean?
water is drawn THROUGH the clothes. There is a BIT of water in the drum - however the water sprays on the clothes during the wash cycle and draws the dirt/water/detergent THROUGH the clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
timer and motor, timer cost about 68USD and motor 130USD you need a qualified repair person to look at it
Feb 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Check the lid switch with a volt/ohm meter for continuity.
If no continuity, replace the lid switch.
Check the direct drive coupling on the motor.
If it will not drain, bad lid switch.
If it will not agitate or spin bad drive coupling.
Feb 27, 2009 | Whirlpool LSQ8000 Top Load Washer
Whirlpool AWM5100 Tests Fine Without Clothes but Stops With Them
Rkwolfers, We would like to inquire further about your post with you. Please respond back to this email address with your name, user id (Rkwolfers), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool AWM6100 Front Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal De
